gas lens part?
发表于 2021-8-31 23:33:29 | 显示全部楼层 |阅读模式
I bought a "lot" at an auction that has many welding rig parts. It came with a CK tig torch and different gas lens components. One of the components, pictured, I do not know how to set up. Can any one help? Attached ImagesMiller TrailBlazer 251Miller HF-250-1Miller MaxStar 150 STLHyperTherm PowerMax 380 plasmaLincoln PowerMig 180Millermatic 252Miller Diversion 180
Reply:Can you flip it over?The peice has a hole in the centre so that gives you a hint?
Reply:The hole is thru. The white center is ceramic and the black is a rubbery coating. The piece is part of a gas lens tig torch assembly that allows short, stubby cups, I think.Miller TrailBlazer 251Miller HF-250-1Miller MaxStar 150 STLHyperTherm PowerMax 380 plasmaLincoln PowerMig 180Millermatic 252Miller Diversion 180
Reply:Do you know the model number of your torch ? (it should be imprinted on the neck)  I can point you to a parts break down....-----------------------Carmen Electrodewww.CarmenElectrode.comand the boss blogs at  www.JoeWelder.comall powered by  www.Arc-Zone.com
Reply:Umm, that's the TIP to a sandblaster, go's on a deadman's nozzle, 100% positive on this oneThere should be a number on it that tells the orifice sizeLast edited by Spar-X; 10-31-2010 at 10:14 PM. SQUARE WAVE 175 TIG   DUAL MIG 151
Reply:Originally Posted by Spar-XUmm, that's the TIP to a sandblaster, go's on a deadman's nozzle, 100% positive on this oneThere should be a number on it that tells the orifice size
GMT+8, 2025-12-26 10:04 , Processed in 0.117800 second(s), 18 queries .
