Mig nozzle with recessed contact tip
发表于 2021-8-31 23:33:29 | 显示全部楼层 |阅读模式
What's the advantage of having a recessed contact tip place of one flush with the nozzle  opening?Jack
Reply:depends. recessed is better for spray and flush/protruding is better for short circuit.
Reply:With a recessed tip you will have less of a chance of burning a tip due to poor technique.
Reply:Recessed tip allows better gas coverage in operations requiring a longer wire stick out length, such as spray transfer and aluminum.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:Originally Posted by JoshDWith a recessed tip you will have less of a chance of burning a tip due to poor technique.
GMT+8, 2025-12-26 08:26 , Processed in 0.101816 second(s), 18 queries .
