Stainless Steel Rotaing Ring of Fire
发表于 2021-8-31 23:33:24 | 显示全部楼层 |阅读模式
Hello, just found this site today, thought i would share some of my work..Fire pit ring, nat gas assist. multilevel, All stainless steel 4' 8" in diameter,   Attached Images
Reply:here is a wider shot, also made some cool skewers Attached Images
Reply:Very nice! Have any shots before it went in the ground?
Reply:or maybe an action shot?There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:Thank you.  This is a Rotating fire pit grill. The bottom would rotate if the gas-line were moved.  I got lucky(over-thunk it) and was very surprised how balanced it came out, before installation. The other pic is before it was cut it in half and came up with the rotating idea. As far as action,, ha , haven't seen any food on it, thanks again. Attached Images
Reply:The title made me think it actually spun. Thinking the grills were burners. would have been AWESOME. Now I'm just disappointed and hungry. thanks a lot.There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:That is very cool. Lets see it in action.
GMT+8, 2025-12-26 08:25 , Processed in 0.094840 second(s), 18 queries .
