MIG Welding Tutorial Video
发表于 2021-8-31 23:32:54 | 显示全部楼层 |阅读模式
Hello everyone,I just put this video together for our local college to use for educational purposes. I thought I would share it on here, as it offers some details on equipment set-up and some actual video of what the actual puddle looks like during welding, which I haven't seen in a welding demo video to-date.[ame]http://www.youtube.com/watch?v=Sb9gHGe9024[/ame]You are more than welcome to use the video for anything you like. The more views the better!Also, we are looking at making some instructional videos for welding projects which people could watch and learn from. At the moment I am hoping for some suggestions on some good starter projects that we could possibly make how to videos about.Any feedback is appreciated TimCarlielleEnterprises.com
Reply:I always liked the projects that could be used, not just built and thrown away. Things like a vice, mig gun holder, small press, small bender, ect.
Reply:weldingtipsandtricks.com lots of close up shots of the puddle with smaw, gmaw, gtaw in all positions, including pipe.....Lincoln pro mig 180Lincoln Square Wave Tig 300/wp 20/home built water cooler Victor, Purox, Harris, O/A welding/cutting setupsVintage Craftsman drill pressVintage Craftsman/Atlas 12"x 36'' lathe7''x 12'' w/c band saw Everlast 140 st
Reply:repeatLincoln pro mig 180Lincoln Square Wave Tig 300/wp 20/home built water cooler Victor, Purox, Harris, O/A welding/cutting setupsVintage Craftsman drill pressVintage Craftsman/Atlas 12"x 36'' lathe7''x 12'' w/c band saw Everlast 140 st
Reply:There is always the great welding cart build projects....  come up with some small scrap metal art samples for the students to copy..Tiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:I would like to see some uphill welding.  I seem to struggle with that the most.  Have problems with it crowning/globbing up.  I used to do fine on the little 110 welder, probably because it was colder, but with my 220 welder I seem to struggle.  A few months back I seemed to do ok, but did some tonight and they came out pretty ugly.I saw the welding tips and trick one, but I would like to see common mistakes and what they look like.  Maybe then I can figure out what my problem is.The Lord has declared, "This is my work and my glory--to bring to pass the immortality and eternal life of man"  Moses 1:39Link: My name is John, and I am a member of The Church of Jesus Christ of Latter-Day Saints.-- ColdCreekWorks.com --
Reply:The 'Best' welding tutorials I've seen come from this site...http://www.mig-welding.co.uk/Rick V 1 Airco Heliwelder 3A/DDR3 CTC 70/90 amp Stick/Tig Inverters in Parallel1 Lincoln MIG PAK 151 Oxy-Acet
Reply:I'd talk more about the actual technique as far as gun position, bracing and patterns, instead of just a close up of the welds.
Reply:DemonSpeederYou have a PMDave ReberWadsworth Ohio
Reply:Very good demo..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Thank you for posting this.  I'd like to see some discussion on and demonstration of too much heat, too little heat, too fast of a travel, too slow of a travel, etc., etc.It's much easier to lay a good bead IF you have the welder dialed in.  Thanks.
Reply:Nice video.We are on our way to being farmers! Our site is always under construction so check back often for updates.  http://www.philosophyfarmstyle.com/
Reply:I especially like how the guy musta drank a red bull right around the 5min mark... Hes just sooooo fast! Miller Diversion 165Rage 2 Chop saw
Reply:Originally Posted by JTDUCATII especially like how the guy musta drank a red bull right around the 5min mark... Hes just sooooo fast!
Reply:yeah I thought he was moving pretty fast.....(thought it was my comp) turn the heat up, get a nice sizzle...and  take your time and watch for the edges to fuse into the puddle... on vertical up  fillet's I like to pause on each toe and in the root.Lincoln pro mig 180Lincoln Square Wave Tig 300/wp 20/home built water cooler Victor, Purox, Harris, O/A welding/cutting setupsVintage Craftsman drill pressVintage Craftsman/Atlas 12"x 36'' lathe7''x 12'' w/c band saw Everlast 140 st
GMT+8, 2025-12-26 08:25 , Processed in 0.113385 second(s), 18 queries .
