Shipboard welding
发表于 2021-8-31 23:32:51 | 显示全部楼层 |阅读模式
I know we have at least one shipyard weldor on this board, but are there any other shipboard weldors out there?If so, what do you use? I mostly stick weld, but tig occasionally. I try to use the Tigmate in the calmest seas possible, and use one hand to steady myself when stick welding.What's your secrets?
Reply:Most shipyards and builders in the south use AC because of arc blow. 6011 or 6027 are the most used.  JohnSMAW,GMAW,FCAW,GTAW,SAW,PAC/PAW/OFCand Shielding Gases.  There all here. :
Reply:I meant weldors who work onboard the ship as crewmembers. I am a marine engineer, and one of my responsibilities is welding.Those who have done so, know exactly what I am talking about, keeping a steady bead while the ship is pitching and rolling.
Reply:I used to be on a ship.  Mostly did demo work at sea, but occasionally did some welding.  Use any body part you can to brace yourself, elbow, shin, hip, shoulder, knee.  It's kind of hard to keep steady when the hoods down and the waves are rolling.
Reply:Oh yeah, and practice.  It'll only get easier.
Reply:I never welded on a floating vessel before but I used to work at a shipyard building them from scratch.  We used dualshield, stick, and some TIG on certain components.
Reply:It is quite an experience, I've been doing it for 20 years. The worst experience I have ever had was standing on a 10' ladder 45' above the main engines. Had to have a harness for that one.
Reply:Originally Posted by WelderBoyI never welded on a floating vessel before but I used to work at a shipyard building them from scratch.  We used dualshield, stick, and some TIG on certain components.
Reply:Originally Posted by YamahammerIt is quite an experience, I've been doing it for 20 years. The worst experience I have ever had was standing on a 10' ladder 45' above the main engines. Had to have a harness for that one.
Reply:Originally Posted by YamahammerI know we have at least one shipyard weldor on this board, but are there any other shipboard weldors out there?If so, what do you use? I mostly stick weld, but tig occasionally. I try to use the Tigmate in the calmest seas possible, and use one hand to steady myself when stick welding.What's your secrets?
Reply:The closest I get to anything like this is building/testing a machine specifically for Bath Iron Works in Maine.
Reply:Question about shipboard welding...well its not quite a ship, its a tug.  Would like to make a new motor platform for a small electric motor and pump.  Owner is concerned about welding onboard due to the amount of electronics.  DDC/MTU main engines with electronic fuel injection, the normal set of alarms, and fly by wire throttle controls.  I understand his concern and have to respect it as the new guy...just started a couple days ago.  Should I be worried?  How can I avoid any issues?  I figured, keep a close ground to the project and maybe use a battery surge tender...Thanks, Tim
Reply:Superarc a while back posted some pictures on the Midway aircraft carrier museum weld shop.  I searched and found the link to that thread, see below.    I'll bet working on a big navy ship in their metal shop would be a kick in the pants!  Wish we had a few old Navy welders here on the forum that were actually stationed on board a huge ship and welded at sea.   I would love to hear some of the stories and working conditions they endured. http://weldingweb.com/vbb/showthread.php...dway+weld+shop "Hey I didn't come to look and learn, I came to turn and burn.... If I can't light up, I'm gonna light out!"-JodyIdealarc 250 "Fatman"MM 252MM 211 "Little boy" Victor Torches
Reply:WOW that is a blast from the past.  I saw Welder Boy's post and none other than Willy Mac.  Check the date on this thread.Charlie
Reply:Old thread, but still great info.Lincoln Power Mig 216Lincoln AC/DC-225/125Miller  625 X-Treme PlasmaMiller 211 Forney 95FI-A 301HF 91110Victor Journeyman O/PMilwaukee DaytonMakita  Baileigh NRA Life Member
GMT+8, 2025-12-26 08:26 , Processed in 0.107089 second(s), 18 queries .
