MIG Spool Gun on TIG machine
发表于 2021-8-31 23:32:46 | 显示全部楼层 |阅读模式
Has anyone heard of this being done?
Reply:You can run a voltage sensing wire feeder on a CC machine, but it doesn't work all that well for most applications. Small wire in short arc runs like cr@p in CC. If the machine has the power you can run large wire FC in spray fairly well, but vertical and overhead will be a real PITA. For what you will probably pay for a VS type feeder, you'd be better off just getting a stand alone 220v mig..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Yeah,I' ve seen a couple of uniformed Chinese clone importers (not us) advertise their tigs would run spool guns, all you had to do was connect it up just because the fittings would interchange.  They also advertise CC only. I've had so many calls on this myself, asking me why we don't do this too. I get tired of explaining, it just ain't gonna happen. Then of course, you will always find the ONE guy that has managed for a brief spurt to make a weld of questionable quality that wants to perpetuate the myth on the internet swear that it will work and start up the calls up again.If you try it, buy a bucket full of contact tips, enough so that you can be fully certain it won't work very well at all.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:Personally, I feel there are different ways of understanding the meaning.  I will choose the meaning that makes sense.  Wire feeding systems exist today, a guy on this forum, named Kevin uses a TIG gun.  http://weldingweb.com/vbb/showthread.php?t=41456 if you scroll to post #8 you can see what I am talking about.TIG stands for tungsten inert gas.  If tungsten isn't where the arc is form to and from, then it isn't TIG.  There are all kinds of options as far as feeding MIG wire into your TIG puddle, you could do this without much of a challenge I would bet.  Sometimes I imagine getting an inverter or converter or whatever it would need to power a spoolgun's motor and then just try to combine the two in hand.I've had plans to make something like this for myself, maybe someday when I have the time I will work on it.Miller 330 a/bp water cooledI believe in gun control, I hold my gun with two hands.  If you want to know why, click here.Buy American or bye America.
Reply:Are you trying to make a tip tig rig for your tig torch by using a wire feeder from a spool gun?
Reply:i have one. it gets the job done, but is far from the quality of weld you can get from a dedicated mig machine. my 330abps has a dealer installed spoolgun kit. the higher the power you go, the better weld you get.Dynasty 200DXPassport plus w/ spoolmate 100victor 315c oxy/(act and prop)Miller digital elitemilwaukee power tools
GMT+8, 2025-12-26 10:23 , Processed in 0.082421 second(s), 18 queries .
