Trying to find a good Oxy/Acetylene Torch!
发表于 2021-8-31 23:32:45 | 显示全部楼层 |阅读模式
I should start out by mentioning that I was on the forum a couple years ago but my old login info has since vanished from my memory. So I'm not the newbie that I appear to be. Anyways I'm about to invest in a oxy/accetylene torch set up. I want something safe and functional that will last. I also would like to continue eating and paying the rent...I found this item on ebay and I know harris is a good company and I'm pretty sure i want to go with 'em. http://cgi.ebay.com/Harris-Steelwork...ht_1534wt_1141Is it bad that the regulators are single stage?I've heard all the best about the victor journeyman, but feel as though it might be an unnecessary leap in quality as I wont be using this that often. But if its worth it I'm sure i could rustle up a deal on ebay. Thanks for the input!
Reply:Single stage is fine, in fact I doubt you would want a 2 stage set. Harris is well known, I wouldn't be afraid to use it. A used torch is a different story altogether, that's when you need to have them inspected and serviced by a pro.City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:That's top quality equipment, and the seller, having an actual retail store that is well stocked, looks to be serious and in for the long haul.Just one thing...  Considering the rate at which some old-line companies are are selling out, I would want to be sure is that it's still the same good 'ol USA Harris equipment. If it is, grab it, you'll be pleased.Good LuckLast edited by denrep; 11-13-2010 at 08:29 PM.
Reply:That kit looks ok - fair deal for a name brand kit.It is a mite shy on welding tips (looks like you only get one) and I didn't see a welding tip unless that what is in the little red/white box.At your LWS, sometimes one can find kits like Praxair or Linde that are rebranded Victor or Harris as much reduced prices.Rick V 1 Airco Heliwelder 3A/DDR3 CTC 70/90 amp Stick/Tig Inverters in Parallel1 Lincoln MIG PAK 151 Oxy-Acet
Reply:There are many good brands out there and you can't go wrong with any of them. The on thing I would look into is how much the cutting tips are going to be to replace, and how easy are they to get. That goes for any welding tips as well.KroekerMiller Trailblazer 302Miller Dial ArcMiller Suitcase 12RCVictor Torch
Reply:Originally Posted by alquinI found this item on ebay and I know harris is a good company and I'm pretty sure i want to go with 'em. http://cgi.ebay.com/Harris-Steelwork...ht_1534wt_1141Is it bad that the regulators are single stage?
Reply:That is a good deal on a good set, you would not go wrong with that. I have used that same set before and really like it. Very durable, pretty inexpensive cutting tips.IAMAW Local 330Airco 300 AC/DC HeliwelderAirco Dip-Pak 200 with Profax spool gunPowr-Kraft AC225Everlast PowerArc 200stBuffalo Forge No.21 drill pressSpeedglas 9100xxAirco, Oxweld, Purox, Victor torchesLincoln Ranger 8
Reply:The price is less than much used gear without the hassle.
Reply:Thanks for all the responses. I think I'm gonna go with the harris.I've found some cutting tips for under $10 and welding tips under $15. Done deal.Now Ive just got build a cart and rent to oxy/ace.Thanks
GMT+8, 2025-12-26 08:25 , Processed in 0.146250 second(s), 18 queries .
