Can I do this?
发表于 2021-8-31 23:32:45 | 显示全部楼层 |阅读模式
Hi all,I have an old welder given to me with no leads.  My question is this, can I safely use ground clamp and electrode holder off of my 100 amp ac stick welder.  It will go on a 230 v ac stick machine iffin it is safe to do so.  As always thx in advance
Reply:Uncle Buck,It's not a matter of welder input voltage but rather and output welding amperage-vs-cable length-vs-duty cycle (60%) as seen in the chart at the end of this link:http://www.pacificcabling.com/Specia...rage_chart.htmMM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Thx Duane,Sorry for the confusion I think, what I meant was I will use different leads of the correct gauge.  I just wanted to steal the ground clamp and electrode holder only on smaller 110 v ac machine. I wasn't going to use those leads.
Reply:Originally Posted by Uncle BuckThx Duane,Sorry for the confusion I think, what I meant was I will use different leads of the correct gauge.  I just wanted to steal the ground clamp and electrode holder only on smaller 110 v ac machine. I wasn't going to use those leads.
GMT+8, 2025-12-26 08:25 , Processed in 0.102581 second(s), 18 queries .
