Need Water Cooled torch for ESAB TIG
发表于 2021-8-31 23:32:43 | 显示全部楼层 |阅读模式
As stated I need a water cooled torch for an older ESAB Heliarc 250(maybe an early '90s model) pictured below.  Just finished my TIG cooler and getting the run around from the local BIG chain welding supplier who just want to sell me a newer TIG instead of picking up a catalogue and making a couple hundred dollars. Anybody got any suggestions?Thanks James L. Attached Images
Reply:I like binzel products, especially for pipe applications such as tig roots etc. They make guns that will retrofit almost any machine/setup. Their a little more expensive than some, but again you pay for quality. In my opinion you cant skimp when it comes to welding equipment if your looking for quality work.
Reply:Weld craft arc zone they are all good you need a #20 series torch. They all sell on line.V.
Reply:I have CNI #20 series water cooled torches brand new... PM me and I can get you up to 4 of them for cheap.Miller Dynasty 300 DXMiller CST280Miller Maxstar 150 STH
Reply:Vinnie, thanks for the shout out!  and we also have CK torches and replacement parts-----------------------Carmen Electrodewww.CarmenElectrode.comand the boss blogs at  www.JoeWelder.comall powered by  www.Arc-Zone.com
GMT+8, 2025-12-26 08:25 , Processed in 0.093835 second(s), 18 queries .
