A Thread Thread
发表于 2021-8-31 23:32:40 | 显示全部楼层 |阅读模式
I needed to make an Acme thingy to use in a build of another thingy.I don't have a jig for attaching round stock "ears" to bolts or other round things.So...................................I need the Acme threaded rod to be hinged.To make sure the axle/pin was true, I welded it to a piece of flat stock.Then used an annular cutter to cut a hole through the round stock, and flat stock, in a single pass.  This left me with an absolutely true axle.Then I welded a piece of extruded tubing in the hole to accept the threaded bar.This is one piece completed.  It will be the imobile part of the assemblyThere is another to do on the next post Attached Images"Any day above ground is a good day"http://www.farmersamm.com/
Reply:This next assembly is the nut assembly which will travel along the threaded rod as the rod is turned.It's slightly different, but the same principle.The axle was welded to the piece of flat stockThen a section of the axle was cut outThen a hole big enough to allow the threaded rod to pass freely was cut through the stockAnd the nut welded on.  The axles, although not touching the nut, will stay true.  Welding in the gap would cause the assembly to bow due to the shrinkageWeird, but it works Attached ImagesLast edited by farmersamm; 09-29-2011 at 09:54 PM.Reason: added an explanation"Any day above ground is a good day"http://www.farmersamm.com/
Reply:I suppose this has something to do w/ the "What the----????" thread. I take it you're not ready to enlighten us about that one.                                              MikeOl' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:Farmersamm- that`s Innovative Thinking in Action!  Very Cool!Rick V 1 Airco Heliwelder 3A/DDR3 CTC 70/90 amp Stick/Tig Inverters in Parallel1 Lincoln MIG PAK 151 Oxy-Acet
Reply:H,mmm   I'm impressed, just not sure exactly why..............
Reply:ha, I was just thinking when I seen the square frame flopped over so far on the lift thingy that your going to need a screw jack or something to adjust & hold the anglemiller 330a bp TIGmiller dynasty 200DX TIGmillermatic 185 MIGthermal dynamics cutmaster 101 plasma cuttersnap-on YA5550 plasma cutterhypertherm powermax 30 plasma cutterbaileigh CS225 cold sawetc....
Reply:Decent source for Acme threaded products?"Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:Originally Posted by Stick-manDecent source for Acme threaded products?
Reply:I needed one to fix my (chineese) Bench Vise.  I got the nut thru Mcmaster Carr.  They were the only ones that i found that had M20 x 4.
Reply:Samm, picture 4 shows nut welded, picture 5 nut not welded.  Is there 2 of these or a change in plans? Bob
Reply:I see there are 2.  Bob
Reply:Originally Posted by farmersammThis is a good sourcehttp://tool.wttool.com/tools/Acme%20Threaded%20Rod
Reply:You might check these out as well as far as the Acme stuff there Stick-man.http://www.use-enco.com/CGI/INLMPI?P...E=58&PMCTLG=01.No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Fastenal stocks it locally in many areas.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:I make my own....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Originally Posted by zapsterI make my own.
Reply:Originally Posted by forhirefarmersamm has a mill but does he have a lathe?can't wait to see the rest of the contraption
Reply:When you go fishing, you use the right bait.  I'm hooked, now tell us what it's for!Got to be something with a heavier load since you used acme thread.  You're pulling something together with the pins I assume.  Probably not pushing since that's a fairly long rod compared to it's thickness.Dynasty200DX w/coolmate1MM210MM VintageESAB miniarc161ltsLincoln AC225Victor O/A, Smith AW1ACutmaster 81IR 2475N7.5FPRage3Jancy USA1019" SBAEAD-200LE
Reply:Very interesting.We are on our way to being farmers! Our site is always under construction so check back often for updates.  http://www.philosophyfarmstyle.com/
GMT+8, 2025-12-26 08:26 , Processed in 0.098130 second(s), 18 queries .
