Welding blanket frame
发表于 2021-8-31 23:32:40 | 显示全部楼层 |阅读模式
I had to make some welding blanket frames to hold my welding blankets, had to protect the garage from hot sparks.
Reply:Very nice.Jack OlsenMy garage website
Reply:I had a vision of one of those frames they use to display hand woven Indian blankets and so on. Not quite the same thing...Nice work. I hadn't thought about using them quite that way..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Nice job!  I'd make one but I just tell people "don't look at the blue light".
Reply:66mynd is thinking along the same lines as I am,, that blanket is pretty low to keep people from getting "eye balled" with the arc!  this is supposed to be a safety item,,, keeping the sparks in control is one thing but why not lift it up to protect the innocent passerby??
Reply:Originally Posted by fuzzykjun66mynd is thinking along the same lines as I am,, that blanket is pretty low to keep people from getting "eye balled" with the arc!  this is supposed to be a safety item,,, keeping the sparks in control is one thing but why not lift it up to protect the innocent passerby??
Reply:See, now I have another project to do.   This would help when I have to weld in my driveway and my neighbors house is only 12 feet from mine with the drive in between.Come try it out and stay a while.
Reply:Very nice... I'm new to the trade. Is it sturdy enough? What size is that 1"?
Reply:im concerned that the sparks will land on the boxes on the shelves and the flames will go through the roof ...i like the frames tho..
Reply:i hang tubing from the ceiling , like with  those small chains that hold your flourescent lamp but a little heavier, on each end of the pipe ............then use shower curtain rings , makes great particians from body working areas , welding , painting.  And takes up zero floor space.        thermal arc 252i  -  millermatic 350P -   miller XMT, cp300ts, 30a 22a feeders, buttload of other millers, handfull of lincolns, couple of esabs  -   Hypertherm 1250 G3
Reply:had a mig spark land in my shirt pocket a few days ago.sadly,it landed on the touch screen of my htc smart phone and that one tiny spark put a crack all the way across.miller thunderbolt 250vlincoln square wave tig 175 prolincoln idealarc mig sp250everlast tig 210EXTeverlast power plasma 50chicago electric (hf) 130 tig/90 arcchicago electric 90 amp flux wire3 sets oxy/acet
Reply:Originally Posted by boatbuoyhad a mig spark land in my shirt pocket a few days ago.sadly,it landed on the touch screen of my htc smart phone and that one tiny spark put a crack all the way across.
Reply:Looks like it will do the job for you.We are on our way to being farmers! Our site is always under construction so check back often for updates.  http://www.philosophyfarmstyle.com/
GMT+8, 2025-12-26 08:26 , Processed in 0.068003 second(s), 18 queries .
