What the.....????
发表于 2021-8-31 23:32:40 | 显示全部楼层 |阅读模式
Near finished on this one.  It'll be put to use before the weekend.Someone ought to guess at what it'll be  It started its life as a $22 Wally World floor jack Attached Images"Any day above ground is a good day"http://www.farmersamm.com/
Reply:It's used for liftiing tires for install I believe..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Nice to see you posting again Samm......zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:laugh.........my wally world jax modded too        thermal arc 252i  -  millermatic 350P -   miller XMT, cp300ts, 30a 22a feeders, buttload of other millers, handfull of lincolns, couple of esabs  -   Hypertherm 1250 G3
Reply:Open Frame, Slow Motion, Fly Swatter!Rick V 1 Airco Heliwelder 3A/DDR3 CTC 70/90 amp Stick/Tig Inverters in Parallel1 Lincoln MIG PAK 151 Oxy-Acet
Reply:Adjustable welding seat?MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:I don't think tires because of the angle. Then I thought if it folded down, using it to pull the duals off to do brakes. But the leverage would be off.Man, I'm stumped!"Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:hmm cant be lifting much weight, those casters are teenyESAB Heliarc 252
Reply:Agreed BlauSchuh.  I can't figure out what's goin' on down at the jack pad.  ???For pulling tires complete with drums and hubs, I just throw down a plastic mud flap or piece of plywood with a little gear oil under the tires, let the jack down until the assembly is "floating"  and slide 'em off.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Originally Posted by Stick-manI don't think tires because of the angle. Then I thought if it folded down, using it to pull the duals off to do brakes. But the leverage would be off.Man, I'm stumped!
Reply:my question is... what goes in those two holes at the top?... He took care to box around the tube on 3 sides.... why?.... hmmmmmmmmmESAB Heliarc 252
Reply:Oh yeah, I got a couple of those. So, I won't give away the surprise for the rest...City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:[QUOTE=BlauSchuh;558531]my question is... what goes in those two holes at the top?... /QUOTE]Restraint chain?Samm?  Where'd ya go?  Samm??!MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:It looks like it could be an unfinished motorcycle lift."These instructions are at our present level ofknowledge. Legal requirements do not exist.Technical issues subject to change."_________________________________________Lincoln MIG PAK 180Lincoln AC-225
Reply:A very slow square bale popper
Reply:Goat dolly.. EZ as that.Lincoln Power MIG 215Lincoln WeldPak 3200HDLincon ProCut 25Lincoln WeldanPower 225 AC/DCIf all else fails... buy more tools
Reply:Foot actuated beer keg crusher...Although why you'd want one of these is a mystery to me..Benson's Mobile Welding - Dayton, OH metro area - AWS Certified Welding Inspector
Reply:A mouse trap for a very large, very slow mouse. Where's the peanut butter go?Brian LeonardAppalachian Ironworks L.L.C.434 Long Branch Rd, Marshall, NC 28753828 649 9966828 702 [email protected]
Reply:Gun target holder.  You can adjust the angle to force them into the ground instead of back at you?
Reply:pretty small holes for chain restraints. I'm going to go with chrome plaited fluter valve clamp.There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:Ya got me stumped! Looks like the hinge point is th "front" axle of the jack, not much width there for torsional stregnth there so... Also looks like it's about at it's stroke limit and the jack is not much more than a pump or two up so it may not be as slow as we are thinking. No left to right loading, kinda fast..... giant beer bottle opener?
Reply:I'm not even sure how the jack actually works in this. as it appears that the "seat" for the jack would pivot past the jack  if the jack is let down at all. it's definately not going to go up any higher as the plate holding the bar that the seat is attached too are welded solid but the bar rotates. And whats with the fork right in front of the jack? that I can see as a chain restraint. The only serious thing I can think it might be is a mower jack. might even pick up a walk behind from the side to allow for work on the blade.There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:I would say some sort of target for shooting.  Maybe a Trans Jack fabbed to your needs?Some Blue , Some Red & Some GreyProverbs 16:2-3.2 "All a person’s ways seem pure to them, but motives are weighed by the Lord. 3 Commit to the Lord whatever you do, and he will establish your plans."
Reply:judging from the pivot point which to me looks like the shaft that runs across  the jack pad, this thing is designed to lift whatever it's supposed to lift at a 90deg angle to the ground, but obviously has a lot of leeway to tilt fore & aft from the 90*... it looks to me like the jack will be able to go full up & down, only way I can see some thinking not is if there assuming the pivot is at the bottom of the square frame but I don't think it is at all, I think it's just floating above the bottom square frame in these shots ... it def looks like a big tire remover to me or something to that effect I guess... although if it was I would expect to see 2 protrusions from the base of the lifting square to place under the tire instead of having to strap the square frame to the tire so maybe not a tire lift, unless it's not done yet miller 330a bp TIGmiller dynasty 200DX TIGmillermatic 185 MIGthermal dynamics cutmaster 101 plasma cuttersnap-on YA5550 plasma cutterhypertherm powermax 30 plasma cutterbaileigh CS225 cold sawetc....
Reply:tractor tire jack all you need now are the up rights and you pieces of pipe on the bottom for the forksLincoln Power Arc 4000 Thermal Arc Fabricator 252 iThermal arc 186Thermal Arc 26 tigTweeko 200 amp spool gunHobart AirForce 400WP-17V-12RI think it's to lift Samm's Dayton wheels.                                        MikeOl' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:yeah forks, couldn't think of the right word for the protrusions miller 330a bp TIGmiller dynasty 200DX TIGmillermatic 185 MIGthermal dynamics cutmaster 101 plasma cuttersnap-on YA5550 plasma cutterhypertherm powermax 30 plasma cutterbaileigh CS225 cold sawetc....
Reply:wered   samm    go  ???  we need answers   already>Innovations are what i leave behind for History
Reply:Tractor rear dual remover? Looks like it would slide a rim dual into place nicely........
Reply:its a side lift jack so he doesnt hav to weld like this anymor Attached Images        thermal arc 252i  -  millermatic 350P -   miller XMT, cp300ts, 30a 22a feeders, buttload of other millers, handfull of lincolns, couple of esabs  -   Hypertherm 1250 G3
Reply:samm.......... before......... the wally jack Attached Images        thermal arc 252i  -  millermatic 350P -   miller XMT, cp300ts, 30a 22a feeders, buttload of other millers, handfull of lincolns, couple of esabs  -   Hypertherm 1250 G3
Reply:It is a hydraulic positioner for a long wave RF antenna used for contacting ancient spirits and extraterrestrial aliens.    Can also be used for lifting beer kegs onto the lower shelf of the refrigerator.  Member, AWSLincoln ProMIG 140Lincoln AC TombstoneCraftsman Lathe 12 x 24 c1935Atlas MFC Horizontal MillCraftsman Commercial Lathe 12 x 36 c1970- - - I'll just keep on keepin' on.
Reply:It's a lift for getting the woman you take home at closing time in your truck.  Right?
Reply:He PM'ed me and noted a clue... the plans came from Oxymoron as he recallsLincoln Power MIG 215Lincoln WeldPak 3200HDLincon ProCut 25Lincoln WeldanPower 225 AC/DCIf all else fails... buy more tools
Reply:I've got it. It's a head from orofice removal jack.There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:Some sort of trap to snatch all those hottie farm-hands you famously show pictures of.Dave ReberWadsworth Ohio
Reply:how about a frame for an Adirondack adjustable creeper for working under those trucks.miller thunderbolt 250vlincoln square wave tig 175 prolincoln idealarc mig sp250everlast tig 210EXTeverlast power plasma 50chicago electric (hf) 130 tig/90 arcchicago electric 90 amp flux wire3 sets oxy/acet
Reply:To stump break cows with?Semper FiJesus may have been a Carpenter, but his dad was a Millwright" A grinder and a can of paint, will make a welder what he aint' "I've done so much, with so little, for so long, that now I can do anything with nothing!
Reply:looks to me like a som bitch that goes to the mother ****er on that piece of **** over there.I forgot how to change this.
Reply:Nooooooo.That's gonna be used to hoist up into the cab all of the required CMV compliance documentation for DOT, PSC, FMCSA, CSA 2010... etc.
Reply:Originally Posted by denrepNooooooo.That's gonna be used to hoist up into the cab all of the required CMV compliance documentation for DOT, PSC, FMCSA, CSA 2010... etc.
Reply:Mike was rightDoing the final tweaking on the adjustable rod length, and handle position.  Then it's off to the races Attached Images"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Originally Posted by farmersammMike was rightDoing the final tweaking on the adjustable rod length, and handle position.  Then it's off to the races
Reply:That's slick.
Reply:Back saver special. "The things that will destroy America are prosperity at any price, peace at any price, safety first instead of duty first, the love of soft living and the get rich quick theory of life." -Theodore Roosevelt
Reply:Well, thanks, but I wasn't totally right. I said to lift the wheels. You're using it for the hubs. Close enough I guess.                                    MikeOl' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:Nice work Samm.Shoot.... I though for sure it was for hoisting paperwork.Well at least "ICC" ain't on the list anymore.Alfred and company celebrated for two weeks straight when the ICC was abolished.  Now they'd probably party for a month if one of the mentioned agencies took a hit.
Reply:That truly is a backsaver, Samm. Good thinking coming up w/ that!!                                          MikeOl' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:Hats off to ya Samm, that is awesome!Likes;- Impressive ingenuity. - Very neat, clean and functional, as always!!!- Saves the backDislikes;- Having to store it.- Will you use it often enough, to want to store it?!!!I think you should rent it out to help justify it. I bought a trans jack for semi's. I used it once and have been storing it ever since. I only paid as much as I would have spent on rental though."Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
GMT+8, 2025-12-26 08:25 , Processed in 0.126591 second(s), 18 queries .
