Welding stainless question
发表于 2021-8-31 23:32:39 | 显示全部楼层 |阅读模式
Hi all:Have a question about welding stainless with a mig. I cannot get the proper cover gas affordably here locally. Could I use my CO2 argon mix?Brian
Reply:SS Mig would need at least argon and 02 if not a tri-mix gas has been a few threads on this topic try using the search featureidealarc 250/250 ac-dc tigidealarc 250/250 ac-dc tig #2 used for sticklincoln sp100hh125dual arbor grinder polisher30 yrs of hand tools52 pitch blocks 6p-26prake gauge -pitch gaugeG&D prop repair 918-207-6938Hulbert,okla 74441
Reply:an argon co2 mix will create a dull bead with little penetration.Dynasty 200DXPassport plus w/ spoolmate 100victor 315c oxy/(act and prop)Miller digital elitemilwaukee power tools
Reply:It depends what argon/co2 mix you've got. If it's got more than 5% co2 then it'll work, but not that well, 2.5% co2 is ideal.
Reply:Hey Brian,You will need a mix of LESS than 5% CO2, not more as Baila suggested that would work. I use C2(98/Ar-2/CO2) for my SS repairs & light SS welding...... & that mix doesn't produce a "dull" bead. Besides, a dull bead can easily be rectified with a SS wire wheel quite nicely.DennyComplete Welding/Machine/Fab. ShopMobile UnitFinally retired*Moderator*"A man's word is his honor...without honor there is nothing.""Words are like bullets.... Once they leave your muzzle, you cannot get them back."
Reply:You could always switch to a dual shield stainless wire(flux core) that runs with Ar 75/C 25.
Reply:Originally Posted by yorkiepapHey Brian,You will need a mix of LESS than 5% CO2, not more as Baila suggested that would work. I use C2(98/Ar-2/CO2) for my SS repairs & light SS welding...... & that mix doesn't produce a "dull" bead. Besides, a dull bead can easily be rectified with a SS wire wheel quite nicely.Denny
Reply:Originally Posted by welds4dYou could always switch to a dual shield stainless wire(flux core) that runs with Ar 75/C 25.
Reply:Originally Posted by Baila La Pinza...Just make sure that you're sitting down when they tell you how much it costs.
Reply:What are you welding and how good looking weld do you want?  I've used straight argon with my mig welder (before I got my TIG).
Reply:http://weldingweb.com/vbb/showthread.php...673#post559673
Reply:I was givin a 4' x 2' piece of 3/8" thick SS plate to make a flat top griddle for my hotdog cart. I need to weld back and side splash guards on it as well as locating tabs and a grease trap. I will keep looking for the tri mixG.
GMT+8, 2025-12-26 10:06 , Processed in 0.127910 second(s), 18 queries .
