Noob question: Stainless cart as welding table
发表于 2021-8-31 23:32:36 | 显示全部楼层 |阅读模式
I've got an old stainless steel table on wheels with some mild steel shelves on it. I was wondering if it was unwise to put the welder on one of the shelves, ground clamp to the table and weld like that?Somehow I feel like I would be creating a close loop (zapping everything on the board) and thus not recommended. But I see tanks attached to welding tables and such too and that doesn't seem to be a problem?Fire away  I know it's probably dumb and need an alternative setup.Hobart Handler 125 #500495Miller Diversion 165 #907005 (tig learning box)
Reply:My welders sit on the lower shelf of a Miller welding table.  Grounded to the table and all shelves metal.  Welders do have insulating feet on them.Never had a problem.TA Arcmaster 300CM3XMT 304S22P12 suitcase feederX-Treme 12VSOptima pulserTA161SMaxstar 150STLHypertherm PM45OP setupStihl 020AVP, 039, 066 Magnum
Reply:Originally Posted by Drf255My welders sit on the lower shelf of a Miller welding table.  Grounded to the table and all shelves metal.  Welders do have insulating feet on them.Never had a problem.
GMT+8, 2025-12-26 08:26 , Processed in 0.086769 second(s), 18 queries .
