New tig torch
发表于 2021-8-31 23:32:28 | 显示全部楼层 |阅读模式
Just got my new syncrowave 200 and coolmate1.Im thinking a CK20 torch and 25 foot superflex hoses.Can  anyone please tell me what dinse adapter I will need?   Thanks in advance
Reply:It should be a miller 195377.  It's a 50 series Dinse that your torch will thread into the back of, and there will be a fitting coming off at 90* the water will flow out of back to your cooler..  The coolest water feeds the torch head, then returns over the power cable to the Dinse connector.I have a homemade version that you can just put into a regular Dinse 50 an cover with pipe insulation.  If you're itching to use your machine this weekend, you can stop by and take it for nothing.  I'm on LI too.  If I can find the post I'll add the link.AlLast edited by Drf255; 05-25-2013 at 05:08 AM.TA Arcmaster 300CM3XMT 304S22P12 suitcase feederX-Treme 12VSOptima pulserTA161SMaxstar 150STLHypertherm PM45OP setupStihl 020AVP, 039, 066 Magnum
Reply:Heres the thread that pictures the connector I made.  I also have a 25' water line for the return water to your cooler.  http://weldingweb.com/vbb/showthread.php...ight=ConnectorTA Arcmaster 300CM3XMT 304S22P12 suitcase feederX-Treme 12VSOptima pulserTA161SMaxstar 150STLHypertherm PM45OP setupStihl 020AVP, 039, 066 Magnum
GMT+8, 2025-12-26 11:56 , Processed in 0.091217 second(s), 18 queries .
