Stainless filler rod questions
发表于 2021-8-31 23:32:28 | 显示全部楼层 |阅读模式
Why the 308 is mostly recommended to weld 304 SS grade ? If 308 and 308L are the mostly used for welding 304 and 304L SS why 304 and 304L filler rod exist ???Is that possible to make a good weld on 304 SS grade with 304 filler rod ?What.s the difference with 308 and 304 filler rod ?Calculator > Bevel Square
Reply:There's a little more Cr and Ni in 308. Helps keep the ferrite content in check in the molten puddle and help prevent hot cracking.
Reply:@ LayoutMan - answers found within http://weldingweb.com/vbb/showthread.php?t=64336."Discovery is to see what everybody else has seen, and to think what nobody else has thought" - Albert Szent-Gyorgyi
Reply:I've never even seen a 304 wire in 30 years of TIG welding,
Reply:Thanks ManoKai!!!Calculator > Bevel Square
GMT+8, 2025-12-26 10:30 , Processed in 0.092941 second(s), 18 queries .
