Cooking spray as anti spatter
发表于 2021-8-31 23:32:27 | 显示全部楼层 |阅读模式
For you guys that use Pam cooking spray as anti spatter, how do you do it?Do you have to wipe it off at the weld joint, or can you weld right thru it?ThanksSafety 3rdGump
Reply:Originally Posted by GumpFor you guys that use Pam cooking spray as anti spatter, how do you do it?Do you have to wipe it off at the weld joint, or can you weld right thru it?Thanks
GMT+8, 2025-12-26 10:30 , Processed in 0.090928 second(s), 18 queries .
