查看: 2|回复: 0
Portable Oxy Outfit
发表于 2021-8-31 23:32:27 | 显示全部楼层 |阅读模式
How do these portable tanks work as far as filling? I see you can buy these with empty bottles, so any LWS will fill them? Can you fill them yourself from larger cylinders? Looks like this guy is giving these away...http://raleigh.craigslist.org/tls/3827982490.html
Reply:I keep a set of "burglar bottles" for small out of shop use.  They are user owned tanks and possession is considered proof of ownership.  The small tanks are sold only, never leased.  The LWS will trade up and give you credit for the tanks you have, if you go up to a B cylinder acetylene and a larger oxygen bottle. Just take them into any LWS and they exchange them for you.That is an awfully small set though.  The MC acetylene is going to MAXED out supplying even the smallest cutting tip.  The MC tank fitting is different from a B cylinder so you will need an adapter for the regulator as well.RogerOld, Tired, and GRUMPYSalesman will call, Batteries not included, Assembly is required, and FREE ADVICE IS WORTH EXACTLY WHAT YOU PAY FOR IT!Dial Arc 250HFThunderbolt 225 AC/DCAssorted A/O torches
Reply:I refill inert gasses, but never acet or oxy. Those will not last very long. I would look for a small, but bigger than that, oxy cylinder and maybe a 5# propane."Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:100.00 bux ain't bad for the regs and torchAs mentioned the tanks are way to small for most metal work.Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:I have a larger set of bottles, just looking at the bargain...thought I could just fill them from mine if needed....
Reply:NOW click the link and see what ya get......gone...
GMT+8, 2025-12-26 10:23 , Processed in 0.069189 second(s), 18 queries .
