very scary weld pics time
发表于 2021-8-31 23:32:23 | 显示全部楼层 |阅读模式
http://honda-tech.com/showthread.php?t=2612390&page=5I link directly to page 5 as some of the scariest stuff is there.this guy is 'welding' axles, suspension arms, suspension mounting points, any type of engine related plumbing you can imagine, roll cage, motor mounts and mounting points..All of it is very scary looking.here are some highlights:http://img16.imageshack.us/img16/4111/271020091543.jpghttp://img404.imageshack.us/img404/9...0420102104.jpghttp://img340.imageshack.us/img340/7...0420102213.jpgdriveshaft!!!  http://img38.imageshack.us/img38/2922/141120091600.jpgOddly enough, some of the welds in his build thread are quite good, like the aluminum intake manifold...An amazing project, plenty of enginuity, but scary welding all over..oh and BTW, my welding is jsut as bad as this, but at least I know it.Last edited by jdchmiel; 10-06-2011 at 12:38 PM.Reason: my badmiller syncrowave 250hobart handler 140home made 400 amp engine driven in progress...
Reply:yuup.Welding/Fab Pics: www.UtahWeld.com
Reply:wow -NateMiller Trailblazer 302gMiller Spoolmatic 30aLN-25 x 2Idealarc SP200Hypertherm Powermax 600
Reply:Typical Ricer....  but they also seem to drive with no regard for anyone else's safety so why should you expect they would care if their welds were safe..Tiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:I wonder how he will balance the drive shaft?Learning one rod at a time
Reply:Originally Posted by Vince_oI wonder how he will balance the drive shaft?
Reply:Hopefully they get some video of it going down the track like the one that was posted yesterday. Run one everything OK run two well just sort of fell apart.
Reply:Originally Posted by soutthpaw they also seem to drive with no regard for anyone else's safety .
Reply:Quality!I wonder what the deal is with the trailer in the background with the upper tongue.
Reply:Originally Posted by davidncbrownlead shot...
Reply:Go look at the " I smack my forehead sometimes" thread by hondaruss in the safety forum, make sure you look at the link for the horribly built 4x4 trucks also.....Lincoln pro mig 180Lincoln Square Wave Tig 300/wp 20/home built water cooler Victor, Purox, Harris, O/A welding/cutting setupsVintage Craftsman drill pressVintage Craftsman/Atlas 12"x 36'' lathe7''x 12'' w/c band saw Everlast 140 st
Reply:well at least it'll fall apart on the track instead of the road 350P 30A spool gun cut master 51  syncro 250 other stuff " take a dog off the street and make him prosper and he will not bite you sad the same cannot be said for man" i didnt use punctuation just to piss you off
Reply:Originally Posted by DemonSpeederDoesn't matter, the drive shaft will split into 3 or 4 sections before he has chance to balance it anyway.
Reply:Welding and fabrication skills are pretty limited, but you've got to admit that guy is not afraid to jump in with both feet. He added four wheel drive, four wheel steering and a bigger engine to a Honda civic.
Reply:Originally Posted by SteveDjrWelding and fabrication skills are pretty limited, but you've got to admit that guy is not afraid to jump in with both feet. He added four wheel drive, four wheel steering and a bigger engine to a Honda civic.
Reply:Originally Posted by davidncbrownIt was a joke...
Reply:Hmmmm. looks like a lot of the welds that are on the chinese bike imports into OZ CRAPPOLA !!!
GMT+8, 2025-12-26 10:29 , Processed in 0.077783 second(s), 18 queries .
