Can crusher
发表于 2021-8-31 23:32:23 | 显示全部楼层 |阅读模式
Well, I bought a cheap HF can crusher a while back.  After about a dozen cans it folded up like a pretzel   So I dug in the scrap pile and whipped this up:4"x4" Angle iron 1/4"3/16" plate on the endsNothing fancy, but it works great!I need to make a larger one for the 16 and 24oz cans Miller Syncrowave 200MillerMatic 180 AutoSetHobart Airforce 500iVictor O/A (80cf)
Reply:Nice, we made a few like it at work once.We made the base out of aluminum and used a emergency stop button to activate the cylinder.You just had to hit the large button and let it do it's thing.We were working on making a rack to hold multiple cans and a limit switch that would stop the cycle once the rack was empty.Semper FiJesus may have been a Carpenter, but his dad was a Millwright" A grinder and a can of paint, will make a welder what he aint' "I've done so much, with so little, for so long, that now I can do anything with nothing!
Reply:Looks fun and usefulTim Beeker.
Reply:cool idea makes me want to kick myself for throwing 4 of those in the scrap pile about 8 mo agoLincoln Power Arc 4000 Thermal Arc Fabricator 252 iThermal arc 186Thermal Arc 26 tigTweeko 200 amp spool gunHobart AirForce 400WP-17V-12R
Reply:Originally Posted by skelley521Nice, we made a few like it at work once.We made the base out of aluminum and used a emergency stop button to activate the cylinder.You just had to hit the large button and let it do it's thing.We were working on making a rack to hold multiple cans and a limit switch that would stop the cycle once the rack was empty.
Reply:Yeah, I would keep it simple also.We made the can rack out of 1/8" stainless cold roll. The test model only held a 6pk and we had to add a section of pipe to the top of the ram plate to keep the cans from wanting to fall behind it.We tweaked it a few times and got the demo rack working good.The limit switch took a lot more tweaking as the light cans wouldn't fall through it.We had to add a long arm and attach a shim as a plate near the bottom to sense when the rack was empty.It took a lot of trial; error and tweaking, but we finally got the demo working. We never made the large model though, got bored and moved on.....lolNice can crusher btw Semper FiJesus may have been a Carpenter, but his dad was a Millwright" A grinder and a can of paint, will make a welder what he aint' "I've done so much, with so little, for so long, that now I can do anything with nothing!
Reply:I had ideas for building a can crusher that would work like an old wringer clothes washer.  Two dumpster rollers on a motor driven gear drive rotating on opposite directions.  Run some hard-facing beads accross the rollers to give 'em some traction to keep the cans moving.  A hopper would support a constant feed while the cans get flattened between the rollers! But then I moved to Massachusetts where the cans are worth a nickle each if whole.  The recycle centers won't pay for flattened cans because they need to read the UPC bar code off 'em to justify paying the nickle.  Member, AWSLincoln ProMIG 140Lincoln AC TombstoneCraftsman Lathe 12 x 24 c1935Atlas MFC Horizontal MillCraftsman Commercial Lathe 12 x 36 c1970- - - I'll just keep on keepin' on.
Reply:Originally Posted by MondoBut then I moved to Massachusetts where the cans are worth a nickle each if whole.  The recycle centers won't pay for flattened cans because they need to read the UPC bar code off 'em to justify paying the nickle.
Reply:What is the electronics? And how much to build? I wouldn't mind having oneTorchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:I would like to have info. on the switch. I would like mine to have one like yours. http://weldingweb.com/vbb/showthread.php?t=49552Dave ReberWadsworth Ohio
GMT+8, 2025-12-26 10:23 , Processed in 0.110526 second(s), 18 queries .
