finger brake stand
发表于 2021-8-31 23:32:21 | 显示全部楼层 |阅读模式
this was sitting on a table in the garge, and was not convenient so I made up the cart. The cast consists of some 2 x 2, along with 2 x 4 tube and the mounts are oversize 2 x2, so that I can slip in someother small bender and a vise.Ron Attached Images
Reply:Not bad.can you bend 1/8" aluminum on that?www.thefusionsolution.com
Reply:1/8 is a little tough 16 gauge is not a problem, with 1/8 it will roll the edge and is a struggle, the 16 is nice clean crisp edge and that is what I bought it for.
Reply:hmmm.. damn.. I need something to be able to do 1/8".. I have a little HF brake that I modified, it works, but I want a box and pan...www.thefusionsolution.com
Reply:with a little work, some extra metal, and maybe a little help from a machine shop it will do 1/8.
GMT+8, 2025-12-26 10:23 , Processed in 0.096813 second(s), 18 queries .
