can you use
发表于 2021-8-31 23:32:18 | 显示全部楼层 |阅读模式
Can you use Cylinders of helium, c25, and 100% argon laying down? I see why not but just want to double check .Lincoln Power Arc 4000 Thermal Arc Fabricator 252 iThermal arc 186Thermal Arc 26 tigTweeko 200 amp spool gunHobart AirForce 400WP-17V-12R
Reply:I do it all the time. Acetylene tanks is a NO NO though. Can't do it with Co2 liquid, dip tube or whatnot.Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:Thanks joker thats what i thought yeah i knew about Acetylen cause of the acytone in the bottle.Lincoln Power Arc 4000 Thermal Arc Fabricator 252 iThermal arc 186Thermal Arc 26 tigTweeko 200 amp spool gunHobart AirForce 400WP-17V-12R
GMT+8, 2025-12-26 10:23 , Processed in 0.070232 second(s), 18 queries .
