Building a shelf
发表于 2021-8-31 23:32:18 | 显示全部楼层 |阅读模式
Good Morning Folks,Ive been asked to build a shelf 13' long 16'' wide and 40" high and be capable of holding up 3000 lbs.It will be sitting on the floor and not attached to the wall. Any tips or ideas before I start?Thanks in advance
Reply:use some thick wall pipe square tubing channel or i beam id say atleast quarter inch thick and id take an idea from the shelves the steel yards have what process are you gonna be using?
GMT+8, 2025-12-26 12:06 , Processed in 0.105158 second(s), 18 queries .
