查看: 2|回复: 0
Need Tig Suggestions
发表于 2021-8-31 23:32:16 | 显示全部楼层 |阅读模式
Hi. I am looking for tig machine opinions,was thinkin Lincoln 225 as already have mp 350 with spool gun for thicker materials,was thinkin of doing custom a/c lines,will bigger machines turn down far enough to do light materials,only get good support from local lincoln dealer,thanks
Reply:You need to define "light materials" for us. You should have no issues with the Lincoln 225 http://www.lincolnelectric.com/produ...on-tig-225.asp  5-230 amps is reasonable.
Reply:light materials like aluminum air conditioning lines,am running.047 in my spoolgun,is pretty heavy duty,works well for dump trailers,
GMT+8, 2025-12-26 12:06 , Processed in 0.204462 second(s), 18 queries .
