查看: 2|回复: 0
Tig Table
发表于 2021-8-31 23:32:14 | 显示全部楼层 |阅读模式
I had an idea for a small table that I could Tig small projects.  with alot of clamping options.  Its made from all scrap material,  the top is 1/2 inch A36 (14 x 28),  the frame is all scrap Angle Iron,  the wheels came from an old Lawn mower.  By the time I cut all of the material,  ground off all the rust, fit it all together, stick welded it up, I had about 8 hours over 2 days.   The top I took to work put it on one of our Cnc Mills drilled 5/8 diameter holes (48 all together) on 2 inch centers,  took maybe 30 minutes.   I wanted to be able to sit in a regular folding chair and weld. Attached Images
Reply:Wow, your pretty strong to be lifting those heavy projects for such a young sister! City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:Looks like a home run to me.  Great idea for the strong hand style clamp holes and I like the rear wheels idea too.  Maybe put a couple of small swivel casters up frony that drop down when not needed to prevent movement and add a couple of reciever boxes for a grinder, chop saw of vise.  Otherwise I am all for recycling used material and getting something usefull and practice at the same time.  Great idea!!BobI'm spending my Kids inheritance, I dont like him that much anyway!!!!!!Enuff tools to do the job, enough sense to use em.Anybody got a spare set of kidneys?  Trade?
Reply:Looks great,good idea!
GMT+8, 2025-12-26 10:30 , Processed in 0.068707 second(s), 18 queries .
