SA 200 Remote
发表于 2021-8-31 23:32:09 | 显示全部楼层 |阅读模式
Does anyone know what kinda cable i should use for a remote. It ain't just a regular extension cord is it?
Reply:A good quality 12 ga. 3 wire ext. cord is all that is required.Only when the last tree has died and the last river has been poisoned and the last fish has been caught will we realize we cannot eat money.                                         -Cree Indian ProverbSA 200 LincolnVictor Torches
Reply:When i first fire it up it turn on just fine, but after an hour or so if i shut it off it cranks over and over (puffs of black smoke) then fires up. What is going on with it and what should be the proper fix?
Reply:Sounds like trash in the needle valve of the carburetor is causing it to flood out.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Originally Posted by Texas"T"Does anyone know what kinda cable i should use for a remote. It ain't just a regular extension cord is it?
Reply:Really only need 3-wire to accomplish that.Don't recall who posted this up originally but here's one common way to wire up a remote with functioning auxiliary power outlet.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:. . . and to clarify, the intent in the above diagram is to use a short pigtail with standard 115V cord connector for the remote outlet.  If a receptacle mounted in the control panel is to be used it needs to be one with an isolated ground that can be found at Home Depot or Lowes.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
GMT+8, 2025-12-26 10:30 , Processed in 0.122424 second(s), 18 queries .
