How dangerous??
发表于 2021-8-31 23:32:08 | 显示全部楼层 |阅读模式
Is it dangerous to use oxy-propane when the cylinders have been on there sides with a few hours! ?
Reply:No. You shouldn't have any issues with either one. Only acetylene needs to be kept upright prior to and during use. O2 can be used sideways if need be, and propane, being in a liquid/gas state in a hollow cylinder is good to go as soon as you turn the cylinder the correct way up. In fact they make both liquid and gas draw propane cylinders designed for horizontal use in forklifts. IIRC the gas draw "horizontal" forklift cylinders will work either horizontal or vertical..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Shouldnt be one bit.Acetylene is absorbed in acetone and a medium, so it needs to sit vertically for a while to be safe.  Propane can just be stood upright and be good to goEDIT.   DSW beat me to it.TA Arcmaster 300CM3XMT 304S22P12 suitcase feederX-Treme 12VSOptima pulserTA161SMaxstar 150STLHypertherm PM45OP setupStihl 020AVP, 039, 066 Magnum
Reply:Originally Posted by Drf255EDIT.   DSW beat me to it.
Reply:Thanks lads
GMT+8, 2025-12-26 11:56 , Processed in 0.099218 second(s), 18 queries .
