Tried to Tig today.
发表于 2021-8-31 23:32:06 | 显示全部楼层 |阅读模式
I tried to tig today scratch start. I need lots more practice first pic left handed no filler the rest are right handed with filler. Attached Imageshttp://www.facebook.com/profile.php?id=100000825140116 Lincoln Weldanpower Model # AC-225/DC-210/6 portable,LN-25 suitcase feeder,Harbor Freight 80 AMP Inverter DC Tig
Reply:hmm, seems your camera is focusing on things other than your welds SQUARE WAVE 175 TIG   DUAL MIG 151
Reply:You steel needs to be cleaned.Ya gotta spend money to make money!
Reply:very clean, also try and keep consistent travel speed as well as dips with filler.
Reply:One problem I have is I pull the filler rod out to far.I ground the steel shiny but had no acetone to wipe it with. Well its not rod but mig wire twisted together.Going to see a doc about my back in the am will get new rod and acetone.Thanks guys.http://www.facebook.com/profile.php?id=100000825140116 Lincoln Weldanpower Model # AC-225/DC-210/6 portable,LN-25 suitcase feeder,Harbor Freight 80 AMP Inverter DC Tig
Reply:weld up a brace for that camera, please!
Reply:From what little I can see, it is a good thing that the picture is out of focus.Just a wild guess, you may not be aware that TIG requires a very small distance between the tip of the tungsten and the work surface, roughly 1/16 to 1/8" for manual welding.
Reply:L to R no filler on first one rest with filler.Hope the pics are improving . Attached Imageshttp://www.facebook.com/profile.php?id=100000825140116 Lincoln Weldanpower Model # AC-225/DC-210/6 portable,LN-25 suitcase feeder,Harbor Freight 80 AMP Inverter DC Tig
Reply:work on consistency with moving the torch and adding filler, and looks like your holding your tungsten to high off  the base metal, should only be like 1/8 max
Reply:How wide should my welds be?http://www.facebook.com/profile.php?id=100000825140116 Lincoln Weldanpower Model # AC-225/DC-210/6 portable,LN-25 suitcase feeder,Harbor Freight 80 AMP Inverter DC Tig
Reply:Another pic.Last edited by nk14zp; 11-14-2010 at 05:48 PM.Reason: bad pichttp://www.facebook.com/profile.php?id=100000825140116 Lincoln Weldanpower Model # AC-225/DC-210/6 portable,LN-25 suitcase feeder,Harbor Freight 80 AMP Inverter DC Tig
Reply:Disregard.http://www.facebook.com/profile.php?id=100000825140116 Lincoln Weldanpower Model # AC-225/DC-210/6 portable,LN-25 suitcase feeder,Harbor Freight 80 AMP Inverter DC Tig
Reply:not too bad though for just starting out. I have seen much much worse from self proclaimed "experts" before keep it up and dont forget the pics!
Reply:What is causing that brown color on the outside of the weld in the very first pic? I have had that occasionally
GMT+8, 2025-12-26 11:56 , Processed in 0.108903 second(s), 18 queries .
