alumin mig
发表于 2021-8-31 23:32:05 | 显示全部楼层 |阅读模式
will .035 or .045 alumin feed thrugth a 10' cable thrugth a ln  25
Reply:I have been told only with a push/pull gun. I saw somewhere though that you could do it with the 5000 series wire as it is stronger. But I do not know that for fact. You must use U drive rollers though.Luke
Reply:do  a search for extreme 4x4 aluminum episode they had a show on hooking up the lil units to run al with out a spool gun350P 30A spool gun cut master 51  syncro 250 other stuff " take a dog off the street and make him prosper and he will not bite you sad the same cannot be said for man" i didnt use punctuation just to piss you off
Reply:Glad hotrodder understood your guestion.  I kind of lost track after the word "cable"Miller Syncrowave 350Millermatic 252/ 30A spoolgunMiller Bobcat 225g w/ 3545 spoolgunLincoln PowerArc4000Lincoln 175 Mig  Lincoln 135 Mig Everlast 250EX TigCentury ac/dc 230 amp stickVictor O/AHypertherm 1000 plasma
Reply:Also if you are going to try this you need a non metallic liner.Luke
Reply:I was going to get a 10'  gun with a plastic linet so the aluminum will hapefull slip througth. thanks everybod, Jim
Reply:It will work.I did the same thing and welded a transmission bellhousing out of a honda and it worked great.Make sure you have no bends in your liner or it will get kinked.Also they sell a couple differnt types of aluminum wire.You will need the stiffer one.Not sure off hand the number tho.
GMT+8, 2025-12-26 10:30 , Processed in 0.108197 second(s), 18 queries .
