Using a positioner
发表于 2021-8-31 23:32:03 | 显示全部楼层 |阅读模式
I had some side jobs that involved welding various 1 1/2" ~ 3" pipe to flanges. When I got to the shop, one guy had been working on the fit-ups with little success.  So I showed him a few short cuts and we whipped it out in no time flat. The drawings called out for overall dimensions, so I measured the inside of the flange to the outside flange face of both ends, did some math and tacked in some scrap so I could get my overall.  I went about 1/16" longer because of weld shrinkage.  Then I 2-holed it in the vice and  then did the same for the loose flange. I also video taped one of the larger assemblies. It was a little tricky with flanges and plates getting in the way.  Unfortunately, I failed to take photos of the finished welds. The first welds were a little rough, but it looked pretty nice towards the end. Attached ImagesCommon sense in an uncommon degree is what the world calls wisdom.
Reply:Clever method of aligning the flanges.  Are those commercial or home made tools? jimDynasty 300DXSmith He/Ar gas mixerMM350PHobart Handler 120Smith LW7, MW5, AW1A
Reply:agreed i really dig that two hole setupVantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:I'm not sure what brands they were, but I found them pretty quickly on google:http://www.google.com/products/catal...ed=0CHgQ8wIwAQCommon sense in an uncommon degree is what the world calls wisdom.
Reply:outstanding im going to have to pick a set up for my pipefitters tool box.Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:those are two hole pins, flange wizard makes them along with a few others. makes fabing easy and precise. I still use a basic torpedo level for field work though. just a little faster.
Reply:I was using two different styles.. One set screwed together through the hole and the other slid together.  I liked the screw type because it didnt slack off while I was messing around but it took longer because of all the threads.  The slide-on type was quick but you had to make sure they didnt slack off from moving things around.Common sense in an uncommon degree is what the world calls wisdom.
GMT+8, 2025-12-26 10:29 , Processed in 0.098340 second(s), 18 queries .
