Built a cart for my Migmaster 250
发表于 2021-8-31 23:32:03 | 显示全部楼层 |阅读模式
The stock wheels that come on the machine seem fine in the shop where the concrete is clean and smooth but awful on my rough asphalt,so I had some old high quality roller bearing dumpsters wheel laying around,6 pieces of 2 1/4 by 16 inch square tubing and a Saturday to shoot and came up with this. I feel its a worth while upgrade on any 250 machine if you need it to be a little more mobile.here is a link to some more photos..jim   https://picasaweb.google.com/1114721...orMigmaster250 Attached ImagesEsab Multimaster 260Esab Caddy160IEsab 161 STLESAB powercut 650Esab 220i tigLincoln Precision Tig 225Lincoln IdealArc 250INE SKYLINE 1500Klutch 140iMEASURE TWICE IS FOR MORONS
Reply:did you have any issues with the head transfering to the bearings in the caster? every time I've tried welding casters on it's melted the grease out of the bearing.There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:I didn't,,but I did degrease and power wash them before I started...jimEsab Multimaster 260Esab Caddy160IEsab 161 STLESAB powercut 650Esab 220i tigLincoln Precision Tig 225Lincoln IdealArc 250INE SKYLINE 1500Klutch 140iMEASURE TWICE IS FOR MORONS
GMT+8, 2025-12-26 10:30 , Processed in 0.094911 second(s), 18 queries .
