Painting a hood?
发表于 2021-8-31 23:32:01 | 显示全部楼层 |阅读模式
i would like to paint my auto darkening helmet how would i do this? im first going to remove the lense but what special prep should i do like sanding? ive never painted plastics before so i dont know if its just like painting wood and metal will spray paint work?
Reply:If a quick and cheap way go with the spray paint. I reckon they make a type of paint for out door patio furniture, and also there is car bumpers, they have a type of paint for that too.
Reply:Just clean it up good and follow the directions on the rattle can for re-coat times.Too soon and you'll get an orange peel effect.Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:I had a little free time on my hands and I decided to paint my old Selstrom 29311 helmet.The original silver color had seen it's better days and I wanted something a little different. SO,......I shot it with a base/clear in Ford Sonic Blue.Whatcha think? Attached Images
Reply:I'm going to have mine custom airbrushed.  Was thinking of having it wrapped in clear vinyl after to protect it.
Reply:Take lense and headgear out... SPRAY. I used orange krylon fusion for plastic when I did mine. It holds if you don't beat your helmet like I do.The factory CAMO on my Miller Performance has held up great though!
Reply:Spray Bulldog on the plastic before you paint and it will stick a lot better.http://www.wmbarr.com/product.aspx?catid=1&prodid=56
Reply:Originally Posted by Copper headI had a little free time on my hands and I decided to paint my old Selstrom 29311 helmet.The original silver color had seen it's better days and I wanted something a little different. SO,......I shot it with a base/clear in Ford Sonic Blue.Whatcha think?
Reply:epoxy primer the hood prior to painting.tackleexperts.comwww.necessityjigs.comhttps://www.facebook.com/groups/mach...dingequipment/
Reply:Hit an RC shop and buy rc car body paint. Close to the same material and the paint is designed to STICK to the plastic lexan like material of the hood.
Reply:Originally Posted by tig dummyHit an RC shop and buy rc car body paint. Close to the same material and the paint is designed to STICK to the plastic lexan like material of the hood.
GMT+8, 2025-12-26 10:21 , Processed in 0.103585 second(s), 18 queries .
