lincolnPM255 spool gun advice please
发表于 2021-8-31 23:31:58 | 显示全部楼层 |阅读模式
well im pondering a spool gun for my power mig 255 i have a ready welder but the wire speed sucks and it a pain to hook up.(also don't wanna drop a grand if its the same as what ive got) i understand i will need the hookup kit for my machine since its an older 255 what im looking for is info from those who've used the magnum sg vs the magnum 250lx besides the price is the lx that much better of a gun in the long run ive also considered the prince xl  im going to be building some boats so im looking for better performance on 080-100 al also if anyone has had to have either repaired  don't wanna get one that's as expensive to repair as buying a new gun lastly with the spool gun kit can i have both connected to the machine and use either one or do i have to hook and unhook each time thanks for any input as i don't even have anywhere here to check them outLast edited by umahunter; 12-16-2010 at 01:52 AM.350P 30A spool gun cut master 51  syncro 250 other stuff " take a dog off the street and make him prosper and he will not bite you sad the same cannot be said for man" i didnt use punctuation just to piss you off
Reply:If you're going to be using this to manufacture boats, I suggest you forget the spool gun idea and get a push-pull feeder and torch so you can use 12" rolls of wire instead of the tiny and very expensive 4" rolls.  Lincoln makes an awesome push-pull pulse mig, the PowerMig 350MP, as does Miller, the Millermatic 350P.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:im not planning to manufacture just plan on building a couple for myself and if it goes the direction of selling some i may move up to something different later if my budget changesLast edited by umahunter; 12-16-2010 at 11:58 AM.350P 30A spool gun cut master 51  syncro 250 other stuff " take a dog off the street and make him prosper and he will not bite you sad the same cannot be said for man" i didnt use punctuation just to piss you off
Reply:or i may even be interested in a miller 30 a if there is a way to adapt it to my machine and be able to control ipm etc and not loose any features350P 30A spool gun cut master 51  syncro 250 other stuff " take a dog off the street and make him prosper and he will not bite you sad the same cannot be said for man" i didnt use punctuation just to piss you off
GMT+8, 2025-12-26 12:06 , Processed in 0.096150 second(s), 18 queries .
