coolant tank size for water cooled tig?
发表于 2021-8-31 23:31:58 | 显示全部楼层 |阅读模式
I finally have everything for my water cooled set-up. I am using a 290ghp submersible pump. I want to know if i use a 5 gallon tank as my reservoir, would I still need a fan and heat exchanger? I never weld at anything higher than 150 on this welder, and usually not longer than 20-30 minutes without taking a break.Lincoln Square Wave 175 TIGLincoln 110v flux core welder (my 1st)Clarke 180EN MIG
Reply:i dont use a cooling fan or radiator only time it gets warm/hot is if i weld for long periods on max or in the heat of summer (105 here 0kla.idealarc 250/250 ac-dc tigidealarc 250/250 ac-dc tig #2 used for sticklincoln sp100hh125dual arbor grinder polisher30 yrs of hand tools52 pitch blocks 6p-26prake gauge -pitch gaugeG&D prop repair 918-207-6938Hulbert,okla 74441
Reply:how big is your coolant tank?Lincoln Square Wave 175 TIGLincoln 110v flux core welder (my 1st)Clarke 180EN MIG
Reply:a 5 gallon bucket filled half waybeen using this set up for 19 yrs nowfirst pump lasted 15 yrs (littlegiant pond pumpi weld everyday repairing props, lowerunits, and pontoons/boatsidealarc 250/250 ac-dc tigidealarc 250/250 ac-dc tig #2 used for sticklincoln sp100hh125dual arbor grinder polisher30 yrs of hand tools52 pitch blocks 6p-26prake gauge -pitch gaugeG&D prop repair 918-207-6938Hulbert,okla 74441
Reply:12.5 hours welding wide open with a Lincoln idealarc300 on ac got the 5 ish gallons of coolant in my Bernard cooler just over 120 degs with a 70 deg ambient.    No fan No radiator.Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:Thanks! Just the answer(s) I was looking for.Lincoln Square Wave 175 TIGLincoln 110v flux core welder (my 1st)Clarke 180EN MIG
Reply:I'm not up on cooler pump specs, but 290 gal/hour seems like an awful lot of flow for a tig torch coolant pump...MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:Originally Posted by DesertRider33I'm not up on cooler pump specs, but 290 gal/hour seems like an awful lot of flow for a tig torch coolant pump...
Reply:sen2two, I was thinking of doing the same thing, basically a tub of water with a submersable pump for larger jobs. I live in new england with sub zero temps and an unheated garage. I have heard that RV antifreeze can be used as opposed to a much more expensive welder specific antifreeze?? Anyone else heard this or should I stick with what's made for the job??
Reply:I use RV antifreeze and use to work in a shop that used it in ~30 different machines, never had any problems. I have a mid sized pond pump that puts out about 7 gallons an hour when run through the small lines on a tig torch. Welding wide open at 200 amps it will get warm quick but doesn't seem to get any hotter after prolonged use. I have 4 gallons of water in my system fwiw
Reply:Originally Posted by revkev6sen2two, I was thinking of doing the same thing, basically a tub of water with a submersable pump for larger jobs. I live in new england with sub zero temps and an unheated garage. I have heard that RV antifreeze can be used as opposed to a much more expensive welder specific antifreeze?? Anyone else heard this or should I stick with what's made for the job??
Reply:Originally Posted by prop-doctora 5 gallon bucket filled half waybeen using this set up for 19 yrs nowfirst pump lasted 15 yrs (littlegiant pond pumpi weld everyday repairing props, lowerunits, and pontoons/boats
Reply:its an E series  submersible ,little giant,E2-38n i think square looking 300gph 11.8 ft lift first one was round looking  this one is  square ... they have a siteidealarc 250/250 ac-dc tigidealarc 250/250 ac-dc tig #2 used for sticklincoln sp100hh125dual arbor grinder polisher30 yrs of hand tools52 pitch blocks 6p-26prake gauge -pitch gaugeG&D prop repair 918-207-6938Hulbert,okla 74441
GMT+8, 2025-12-26 12:06 , Processed in 0.093157 second(s), 18 queries .
