miller 30a on a lincoln...
发表于 2021-8-31 23:31:57 | 显示全部楼层 |阅读模式
power mig 255 will it work anyone done it did ya loose any features ? trying to Price out all my options in search for the most band for my buck350P 30A spool gun cut master 51  syncro 250 other stuff " take a dog off the street and make him prosper and he will not bite you sad the same cannot be said for man" i didnt use punctuation just to piss you off
Reply:The Spoolmatic 30A wire drive motor runs on 24vac, actually 0-30vac to be more precise.  What spool gun motor control voltage does your Lincoln mig provide on the remote connector?The Lincoln Magnum SG spool gun should be a direct fit for your Lincoln mig....MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:well i called up miller and they said it wouldn't work  im leaning toward the prince xl as i was told the magnum lx is a cheaper unit made off shore i looked at the sg but figure if im gonna spend the money  i want the best i can get for the money350P 30A spool gun cut master 51  syncro 250 other stuff " take a dog off the street and make him prosper and he will not bite you sad the same cannot be said for man" i didnt use punctuation just to piss you off
Reply:The Prince XL is a very nice gun indeed.  I have no idea if it would work with your PowerMig or not.  Contact MK to find out.... www.mkproducts.comMM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:just installed a prince on my 255 came with plumbing and a circuit board. about a pound of aluminum wire through it so far. no hiccups but have a lot to learn welding alum.
Reply:talked to Lincoln today and the prince xl was originally the gun they pushed for my machine( matter of fact my machine has a sticker inside thats states if i buy a prince they'll throw in the module free which no longer applies)  when i got it back in 02 talked to a tec guy and he told me the reason they went to the magnum lx was for a gun with more amp capability my next concern is consumables and availability thanks for the replies350P 30A spool gun cut master 51  syncro 250 other stuff " take a dog off the street and make him prosper and he will not bite you sad the same cannot be said for man" i didnt use punctuation just to piss you off
Reply:Originally Posted by jugheadjust installed a prince on my 255 came with plumbing and a circuit board. about a pound of aluminum wire through it so far. no hiccups but have a lot to learn welding alum.
Reply:The MK tips and nozzles are not cheap and are not normally stocked at local welding suppliers but they can be ordered.  You may want to find out if you can convert it to a Lincoln style front end so you can use Lincoln consumables, assuming Lincoln put their own front end on their version of the Prince gun.  Miller did that with the MK Pythons they sold with their MM350P's and XR feeders.  The Pythons that came our 350P's in the old job used Miller FasTips and nozzles, whereas my MK model Python uses MK parts.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:Lincolns use MK tips, better prices through MK then Lincoln.Esab/Lorch ET-220iEsab 160i caddyThermal LM-200 Lincoln feedersThermal Pee-Wee 85sThermal 60i- 3phase /RPC powered (Beast)Thermal Drag-gun 35CINE 1500 Klutch 140i
Reply:i did find this while searching under prince gun accessories    https://weldingsupply.securesites.co...2:AND:KP2246-1    not sure if this would be what i want ill have to probably try monday and see  im also pondering maybe seeing if i can switch the front end over to hold miller tips since that's the main brand  the 3 shops here carry  most here carry but a handful of Lincoln stuff and thats it i haven't actually ever got Lincoln tips just tewco or radnor thanks for the advice its hard shopping for a Lincoln guy round here nowadaysLast edited by umahunter; 12-18-2010 at 01:06 AM.350P 30A spool gun cut master 51  syncro 250 other stuff " take a dog off the street and make him prosper and he will not bite you sad the same cannot be said for man" i didnt use punctuation just to piss you off
Reply:Originally Posted by umahunterdo you have an older 255 or the newer c or xt ? what i was wondering about the gun was does your machine give you an accurete wire speed on the digital readout  or do you have to just  mess with the speed on the spoolgun handle ??
Reply:i was wondering about that you do get your voltage though right?350P 30A spool gun cut master 51  syncro 250 other stuff " take a dog off the street and make him prosper and he will not bite you sad the same cannot be said for man" i didnt use punctuation just to piss you off
Reply:With the cost of a Prince XL and hook-up kit to fit it to your Lincoln, you may not be all that far off from the price of a Lincoln-ready Python Plus, which will allow you to use full size rolls of wire inside the 255 feeder....MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:ive also pondered that but wasn't sure if i could put that on my machine on another note while looking over the manual for the prince i noticed they have it as a spool gun or push pull gun  and have a kit to use the push pull setup as a spool gun gonna call them Monday and see if it works vise versa the thing i like about the spool gun is to use either or where as with the push pull you have to use one or the other but the push pull does look a helluva lot easier getting in tight then a spool gun350P 30A spool gun cut master 51  syncro 250 other stuff " take a dog off the street and make him prosper and he will not bite you sad the same cannot be said for man" i didnt use punctuation just to piss you off
Reply:Both the Prince XL and the Spoolmatic/XR 15/30 A/W guns can be used as a spool gun as well as a push pull gun, with the necessary parts (spool holder assembly and wire conduit).  My Spoolmatic 15A started out as an XR-15A push-pull, before I put the spool canister assembly on it and took out the wire conduit and changed the plug in to the machine.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
GMT+8, 2025-12-26 10:30 , Processed in 0.071130 second(s), 18 queries .
