MIG welding exhaust?
发表于 2021-8-31 23:31:56 | 显示全部楼层 |阅读模式
I would like to MIG weld Type 409 - 14 Gauge Stainless Steel exhaust tubing, and need to know what type of wire to use? I surmise that pure Argon shielding gas is required.What wire diameter is preferable?Any info on the subject is much appreciated.Bgbkwndo.
Reply:100% argon is usually only used to mig weld alum. All the stainless mig I've done was either with trimix or just plain 75/25 when the weld quality didn't have to be great. For 14 ga I'd probably work with .023 wire or .030 depending if I thought I might need to weld thinner or thicker material as well. Never done 407 so I can't help with filler other than I know it's just barely stainless. All my stuff was 304 or 316..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Download this PDF (from lincoln website) http://content.lincolnelectric.com/p...ure/c64000.pdfYou have 2 choices ER409 and MC409. The MC409 is .045 and requires 98% argon / 2%O2. Other brands will have their own versions.JasonXMT 350 MPA Dynasty 280DXSuitcase 8RC / OptimaSpoolmatic 30AThermco Ar / C02 mixerAssorted O/A gear
GMT+8, 2025-12-26 10:23 , Processed in 0.099614 second(s), 18 queries .
