Work pictures
发表于 2021-8-31 23:31:55 | 显示全部楼层 |阅读模式
Here is a 315 cat bucket that had been flexing at the hinge plate busting top caps and all the way to the backside of the liner busting it also. OEM didnt have braces under caps i have do this to 3 buckets and it seems to help. Attached ImagesLast edited by steve loving; 10-26-2011 at 09:05 PM.
Reply:990 cat boom b pin bores Attached ImagesLast edited by steve loving; 10-26-2011 at 09:05 PM.
Reply:jd 160 lc boom broken mostly off welded ground plated thanks for looking   Steve Attached Images
Reply:Nice, I miss doing stuff like that.I like the bucket modification in particular.
Reply:Nice work! Yeah baby, we like pics of heavy duty stuff!!"Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:Originally Posted by 37ford4drthats manly man stuff for sure
Reply:SteveI hauled a 330 to a job where a Komstsu had a busted boom. Ended going back a few days later to haul it back to the shop for our guys to fix. I was always amazed when they would rebuild the buckets for Vulcan and hanson quries. Lots of time in them.Learning one rod at a time
Reply:Always interesting to see big stuff; thanks for posting!Rick V 1 Airco Heliwelder 3A/DDR3 CTC 70/90 amp Stick/Tig Inverters in Parallel1 Lincoln MIG PAK 151 Oxy-Acet
Reply:maybe a few dumb questions but could you elaborate on the whole repair process.  like what process did you do for the welding,what machine,what settings, thickness of steel?  just curious.  thanks
Reply:Originally Posted by steve lovingHere is a 315 cat bucket that had been flexing at the hinge plate busting top caps and all the way to the backside of the liner busting it also. OEM didnt have braces under caps i have do this to 3 buckets and it seems to help.
Reply:Originally Posted by VPTNo beveling on any of the plate? Is it common to just build up weld on the outside of the plates instead of beveling and getting the weld penetrated to the center of the plate?
Reply:Naaaaa no beveling on this application..Think of it as one big "T" joint..Looks great!You must have a line borer or one big a$$ machine to do the bores with.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:that  bushing repair   is impressive   ,   would like to see  the tools used  .     nice work  bye the way>Innovations are what i leave behind for History
Reply:great work, thanks for sharing.
Reply:Great work!, I would like to get more jobs like these, I really enjoy working on heavy equiptment.Some Blue , Some Red & Some GreyProverbs 16:2-3.2 "All a person’s ways seem pure to them, but motives are weighed by the Lord. 3 Commit to the Lord whatever you do, and he will establish your plans."
Reply:Thanks everyone i should have taken some in between pictures on lineboring the 990 boom.  I used the same bar setup as i did in the d11n rollerframe posted on here a while back but i drove it with a magdrill.  Next time i will do a set up to finish shots.  The holes were built up with 7018 by hand like a caveman would do it. Hopefully soon i will have a borewelder.  The bores in the boom were 6.5 dia and 7.5 deep. Thanks Steve Attached Images
Reply:Wow nice work there. Lots of weld timeHTP Invertig 201Lincoln Idealarc SP250Miller 180 AC StickBy farmall:They should have held the seagull closer to the work, squeezing evenly for best deposition.
GMT+8, 2025-12-26 16:10 , Processed in 0.073112 second(s), 18 queries .
