Home made tool
发表于 2021-8-31 23:31:55 | 显示全部楼层 |阅读模式
I do alot of work on old vws and I the arms always get stuck in the beam and usually you have to give it some love to get them out an some of the bugs I do have painted arms and im always afraid to scratch them. So today I came up with a pulled with stuff laying Around the shop. 1 3/8 Shaft clamp I put in the lathe and opened it up to 1.450 from 1.375 so it could clamp on the arm.. I'm sure there's a tool made for vw arms just never seen on. Also I some delrin that goes on the beam so it doesn't get scratched.. These pictures are from my Baja that I don't care if it gets scratched.  SIN CITY METAL WORKSvisit my YouTube channel https://www.youtube.com/user/devvon
Reply:Also pull a stuck bushing SIN CITY METAL WORKSvisit my YouTube channel https://www.youtube.com/user/devvon
Reply:Nice, you should post that over on www.shoptalkforums.com so your fellow airheads can see it.   If I was on my home computer I would post a pic of my oil pump puller.Century Quick Fix  wire welder, Century Infanite Disc Stick welder, Lincoln Pro-Mig 175, Oxy Acetaline torches.
Reply:The greatest thing about homemade tools is even if you only use it once, you made it and it worked. Good job.
Reply:Nothing better than being able to whip up a tool for the job. Nice work. Thanks for sharing
Reply:I like the principle! Thanks for posting.
Reply:Originally Posted by wd40prerunnerAlso pull a stuck bushing
Reply:Originally Posted by VPTCurious how long it takes you to find the tap you need?
Reply:not to mention... what does "someday" refer to?  *hint hint* tap drawer....
Reply:Originally Posted by slow6inot to mention... what does "someday" refer to?  *hint hint* tap drawer....
Reply:Originally Posted by wd40prerunnersomeday is a motivational quote my grandpa told me... he told me if you start a project never become the someday guy.. always finish what you start,never put it off till someday.
GMT+8, 2025-12-26 16:09 , Processed in 0.096277 second(s), 18 queries .
