Wood on steel gates
发表于 2021-8-31 23:31:54 | 显示全部楼层 |阅读模式
Here's a coupla pics of some gates I finished yesterday. Attached ImagesIan TannerKawasaki KX450 and many other fine tools
Reply:Very nice work.There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:Looks good. What kind of wood and how was it attached?HH 187Miller Bluestar1EAHP AlphaTig 200X
Reply:Nice job.  I think the metal/wood mix look is one of my favorites.  I plan on building something similar for the side yard of my place.
Reply:I agree, I like the wood/metal combo. I made some gates for my front yard out of square tubine with T-111 attached. I used the T-111 thinking it would resist the weather better. I glued and screwed the material in place then stained the whole thing.Cut an MGB and widened 11" C4 Corvette suspension and LT1 Chevrolet power & 6 spd. Pictures here:Part 1http://forum.britishv8.org/read.php?13,7581Part 2http://forum.britishv8.org/read.php?13,22422
Reply:The wood is con. heart redwood.Ian TannerKawasaki KX450 and many other fine tools
Reply:Very nice!Buy American, or don't whine when you end up on the bread line.
Reply:Are these gates relying on the wood for structural strength, or is there some hidden steel creating a frame?Jack OlsenMy garage website
Reply:The gates might be nice, I can't tell... I'm still staring at the garage doors in the first picture.  His and hers RVs?__David Hillman
Reply:The main frame of the gates is 1" square tube. The wood is decorative only.Ian TannerKawasaki KX450 and many other fine tools
Reply:Those are beautifull gates!  You do great work!Some Blue , Some Red & Some GreyProverbs 16:2-3.2 "All a person’s ways seem pure to them, but motives are weighed by the Lord. 3 Commit to the Lord whatever you do, and he will establish your plans."
Reply:Yes - looks mighty fine!Rick V 1 Airco Heliwelder 3A/DDR3 CTC 70/90 amp Stick/Tig Inverters in Parallel1 Lincoln MIG PAK 151 Oxy-Acet
Reply:Forty the gates are beautiful! I love mixed materials also, nice balance. For the driveway gates, where is the 1" square tube on the sides and going across the length? Is it inside the wood or on the back, or? With the people gate, is the wood structural or again tubing? What caught my eye is that the tenon that would be used to create the frame of the wood would have to be pretty small at the scalloped top rail.No critique here, I really love the look, just curious. AC-180 Lincolnwelder circa '50's
Reply:Originally Posted by David HillmanThe gates might be nice, I can't tell... I'm still staring at the garage doors in the first picture.  His and hers RVs?
Reply:I can't comment on the cool stuff behind the big doors. The steel tube is the meat and the redwood is the bread in the gate sandwich. They look the same inside and out, except that there are tiny screw heads showing on the inside, I used trim head deck screws to fasten the wood. Attached ImagesIan TannerKawasaki KX450 and many other fine tools
Reply:Very nice work.Jack OlsenMy garage website
GMT+8, 2025-12-26 16:09 , Processed in 0.095352 second(s), 18 queries .
