fixed my shovel
发表于 2021-8-31 23:31:54 | 显示全部楼层 |阅读模式
we got some snow.. i went to the shed to find my trusty shovel, and there it was, pos handle  was broke off just the way it was last spring..5 minutes in the scrap pile, bend bend twist twist 5 minutes at the tigger..cost of repair  $zero..not jumping on the road to go to hd and fight for the last one..priceless.. Attached Images
Reply:your screw is stripped. www.thefusionsolution.com
Reply:. . . and it will outlast every shovel you ever have to put it on. Let me guess, it replaced one of those plastic handles that's all one sees now days.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:i like your handle, pretty clever design.Im curious why you went with the screw, i wonder if a 1/4" bolt would be stronger or if it would make a difference
Reply:there seems to be some sharp edges and need for paint... Just bustin your balls good improvisation.Miller thunderbolt 250Decastar 135ERecovering tool-o-holic ESAB OAI have been interested or involved in Electrical, Fire Alarm, Auto, Marine, Welding, Electronics ETC to name a just a few. So YES you can own too many tools.
Reply:Just broke the D ring handle of my plastic shovel that I actually liked, think I will copy your handle. Is there a heated version??  LOL"Si Vis Pacem Para Bellum"Lincoln Idealarc 250 AC/DCMillermatic 251   Syncrowave 300   30A spoolgunLincoln MP210Hypertherm 45(2) LN 25(2) Lincoln Weldanpower 225 CV(4) SA200   1 short hood    SA250    SAM 400
Reply:The screw is not stripped, it is a homemade tamperproof!!
Reply:Originally Posted by rexcormackThe screw is not stripped, it is a homemade tamperproof!!
Reply:Nice! What did you use to make the bends?Lincoln Handy mig Longevity Stickweld140Hobart Handler 210
Reply:I like it, though you might want to do some grinding where the handle connects to the bent pieces. those parts will tear up a pair of gloves/hands quickly.There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:Nice repair.
Reply:many thanks to my friends and ballbreakers..Duaneb55   yup a plastic cheapy, but it works and its paid for..(first foto)smokin dodge..i agree.. but i found the screw first and wanted to get er done..loanshark..i used a simple bending fork..bend a little, move 1/4" repeat...(2nd and 3rd foto)thorshammer..quite right..it doesnt show but i actually washed the sharp spots off with the torch, just tryin to go fast andget done..the handle is a good bit wider than my hand so there wont be much contact.. Attached Images
Reply:I would peen that screw head down and over flat and stamp my initials in it. Might be so many look alikes that you will need to be able to tell each other apart. Good job.My favorite snow shovel (when I have to absolutely use one) is the plastic grain shovel. Yeah, those sell out early too. Get your straw hats in Feb and your snow shovels in August.
Reply:You'll be amazed at how often your hand will slide out from the center of that handle.There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:why not run the strapping inside the pipe handle..all problems solvedOf all the things I lost I miss my mind the most...I know just enough about everything to be dangerous......You cant cure stupid..only kill it...
Reply:Nice quick fix, looks permanent!Bruce The Welding ChefLincoln Weld-Pack 3200 NORWELD StickStanford Hill Farm
Reply:I have the same shovel but it it's yellow..Out in the yard somewhere..Won't be needing it until the real winter gets here by the looks of things.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:better go check yer handle.. i only use mine on the decks..the toro does the driveway..
Reply:Originally Posted by roadkillbobbwhy not run the strapping inside the pipe handle..all problems solved
GMT+8, 2025-12-26 16:08 , Processed in 0.118998 second(s), 18 queries .
