查看: 13|回复: 0
Welding table/vise stand
发表于 2021-8-31 23:31:53 | 显示全部楼层 |阅读模式
Reply:OK, I am trying to get photo from photobucket and it isnt working. If I crop to 600x800 then the picture is only a little part of the table. Any suggestions?
Reply:did you copy and paste the link from photobucket that says Image next to it?
Reply:I used paint to resize.
Reply:The photos are reversed. I wanted the table itself first and the one with it holding the start of my welding cart to be second. It didnt work out that way.And please pay no mind to the dirty shop, havent had time or will power to clean up. Mostly lack of will power.
Reply:If you host from photobucket, you can re-size to 800x600.  Don't crop it, just re-size it.  Click on the pic you want to change, hover over it and at a top a menu bar will pop up.  There is an option right there to re-size to 800x600 with one click.Then right-click and copy the image url and the code should look like.  Just remove the space between the [ and the /.  [/IMG][IMG]http://img.photobucket.com/albums/v409/kazlx/2119173e.jpg[ /IMG]
Reply:Thanks, I also figured out how to doit from paint and I dont have to send it anywhere. Paint allows you to resize with out cutting or cropping.
Reply:There is a free software called FotoSizer that allows you to resize pictures in batches. Bestest software ever for resizing pictures before uploading to Imageshack or whatever. If you ask Imageshack to resize it for you, you will need to upload he full size picture to it before it re sizes it. And if you are dealing with 4MB files... it gets slow. Resize before uploading anywhere.Mikel
GMT+8, 2025-12-26 17:44 , Processed in 0.088614 second(s), 18 queries .
