Strength question
发表于 2021-8-31 23:31:52 | 显示全部楼层 |阅读模式
I need to weld a support for a swim deck on my house boat.  The swim deck is 4 feet deep and has a little too much give when standing on the edge.  Here is the question - would a piece of 1x3 tube steel (.065) stood on edge and run at a 45 degree angle (a knee brace) be stronger or weaker than a 1.5" x 1/4" angle iron run in the same configuration?  Any advice on which way I should go?Thanks,Dave
GMT+8, 2025-12-26 16:08 , Processed in 0.086327 second(s), 18 queries .
