how much will an 1/8 inch 6010 5p welding electrode dig into the metal im welding without a bevel?
Reply:Depends on the amps, temp of the steel, travel speed, travel angle..I could go on...Airco Ac/Dc 300 HeliwelderMillerMatic 200 (stolen)Miller Maxstar 150STLMiller AEAD200LE (welding and generating power) Hobart MIG
Reply:Originally Posted by flux core joehow much will an 1/8 inch 6010 5p welding electrode dig into the metal im welding without a bevel?
Reply:Yep crank it up and it will blow through a lot. I use it to blow bolt holes in used grader blades for the Amish to use on their old pull type graders, at about 250 amps it'll blow right through a 5/8 grader blade and leave a nice round holeTrailblazer 302Hobart Stickmate AC/DCLincoln SP 135 TSmith torchSpoolmatic 30A |
