Weave Bead Question
发表于 2021-8-31 23:31:47 | 显示全部楼层 |阅读模式
Is there such a thing as a weave bead with the wire welding process? I know of weaving the electrode with stick, but I tried it with mig and it didn't work out so well. Do I need more practice or is it just not done with wire welding?
Reply:Yes you can weave with mig. My guess is you need more practice. Picts of your attempt would help..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Transfer type has a lot to do with the outcome.
Reply:An overhead spray weave might not work so well, but just about every other wire process I can think of weaves pretty good.Have we all gone mad?
Reply:Im told you dont pause as long at the toe, as you would with stick. Its more fluid motion. But I think that was real MIG, not fluxcore or Spool...Lincoln Power MIG 210 MP ( boat anchor )Lincoln Weld-Pac 100 HDHobart IronMan 230Cutmaster 42Jackson NexGenSumner Ultra ClampsDWM120
GMT+8, 2025-12-26 17:44 , Processed in 0.093371 second(s), 18 queries .
