Help with caping pipe
发表于 2021-8-31 23:31:43 | 显示全部楼层 |阅读模式
I am needing to layout a pattern to close the end of some 5 or 6 inch pipe. It needs to be rounded like the top of a oxygen tank.  The pipe will be used to move large rolls of drainage tile. and cannot be pointed or if the operator misses the center hole the tile will get punctured. Any help would be appreciated thanksWhite Face DialArcMM252Miller Bobcat 225D plusHypertherm 600
Reply:You can buy a hemisphere to cap the end or you can field weld an orange peel cap.Here is a link: http://www.tpub.com/content/construc.../14251_109.htmHope this helps.
Reply:I dont have alto of time i need to get this project together by monday so buying is out but thanks. I couldnt get that link to work very well but thank you anyway.White Face DialArcMM252Miller Bobcat 225D plusHypertherm 600
Reply:got the link to work thanks for the helpWhite Face DialArcMM252Miller Bobcat 225D plusHypertherm 600
Reply:ditto on the orange peal.     the weld on globes are a close second, third is a fence post cap that you can source from the local home depot.Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
GMT+8, 2025-12-26 15:46 , Processed in 0.103326 second(s), 18 queries .
