Workbench im planning on...
发表于 2021-8-31 23:31:42 | 显示全部楼层 |阅读模式
Would like a little bit of input. Its not going to be for any super precise fabrication, but im curious about functional ideas to add to it. Im a millwright and do alot of mechanical repairs on the bench of pumps, motors, etc... or rather will do. Aside from tool storage, what else have you guys found is invaluable in your work benches? Thanks! Heres a sketchup pic. Ill send the skp to anyone who wants it just in case any of you wanna play with it Lemme know what you think! Attached Images
Reply:Through in a couple pieces of  tubing underneath to act as receivers for your vice, grinder, and anything else you want to put on it and you're set.There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:Do you always stand while working?  If not, I think you might regret those braces 20" off the floor.  My table is the same size, and I made it five-legged with one side open, so I can sit and work anywhere along the one side.__David Hillman
Reply:i built one like this last year and added a receiver for my vice and grinder. I also put a bin underneath the cutting area since I am anal about a clean shop.
Reply:Great start.We are on our way to being farmers! Our site is always under construction so check back often for updates.  http://www.philosophyfarmstyle.com/
Reply:dont forget to have a spot to hang C clamps on the sidebobs77vet/37ford4drEastwood digital TIG200HH190Lincoln Invertec 155sLincoln weldpak 100sears/craftsman (lincoln) 50a 240v buzz boxO/A rig Harris gaugesnexion cut 50 dxchicago electric (HF) 240v spot welder
GMT+8, 2025-12-26 16:08 , Processed in 0.070944 second(s), 18 queries .
