Cart for my miller roughneck 1e
发表于 2021-8-31 23:31:41 | 显示全部楼层 |阅读模式
Well was excited to get my welder running again and remembered the pain in the a$$ it was to move it around so I decided to make a cart for it. I grabed some scrap pieces from aroud the shop and this is what I came up withWill   Supports Autism Awareness                            My ToysBobCat 225 PLusMillermatic 130Miller Spectrum 300 CutmateEverlast Power Tig 185 Micro April is Autism Month .
Reply:Need to find some material for some handles and maybe some cable holders.Will   Supports Autism Awareness                            My ToysBobCat 225 PLusMillermatic 130Miller Spectrum 300 CutmateEverlast Power Tig 185 Micro April is Autism Month .
Reply:Some handles and cable wraps will come in handy. I'd think about rerouting that exhaust so it's not blowing in your face when you adjust the machine. Looks like it will fit well between the engine and generator unit. Either that or point it straight up(if it's not left in the rain) or straight out the back. Those options will give you more room on the sides for the leads to go.
Reply:Originally Posted by BistineauSome handles and cable wraps will come in handy. I'd think about rerouting that exhaust so it's not blowing in your face when you adjust the machine. Looks like it will fit well between the engine and generator unit. Either that or point it straight up(if it's not left in the rain) or straight out the back. Those options will give you more room on the sides for the leads to go.
Reply:If you want to save even more headache, you might consider replacing that front leg with a free wheeling wheel (technical terms have never been my forte, but a wheel that can spin a free 360 degrees!)
Reply:Is that a 16 hp Kohler on that?HH 187Miller Bluestar1EAHP AlphaTig 200X
Reply:Originally Posted by GreyhorseIs that a 16 hp Kohler on that?
Reply:Originally Posted by mb_welderIf you want to save even more headache, you might consider replacing that front leg with a free wheeling wheel (technical terms have never been my forte, but a wheel that can spin a free 360 degrees!)
Reply:Looking good Will. You may want to consider moving the axle/tires a little closer to the center to take some weight off the panel end.  That'll make it easier on the casters you're thinking of using off the grocery cart (buggy down here ).  Especially if you plan on hanging the leads on there end as would be typical.Keep the photos coming.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Originally Posted by duaneb55Looking good Will. You may want to consider moving the axle/tires a little closer to the center to take some weight off the panel end.  That'll make it easier on the casters you're thinking of using off the grocery cart (buggy down here ).  Especially if you plan on hanging the leads on there end as would be typical.Keep the photos coming.
Reply:Here it is with some handles I made for it.Will   Supports Autism Awareness                            My ToysBobCat 225 PLusMillermatic 130Miller Spectrum 300 CutmateEverlast Power Tig 185 Micro April is Autism Month .
Reply:Originally Posted by dumb as a stumpand perhaps some support for that muffler
Reply:If you look close you can see the bracket toward the end. Sorry the picture was a little blury.Will   Supports Autism Awareness                            My ToysBobCat 225 PLusMillermatic 130Miller Spectrum 300 CutmateEverlast Power Tig 185 Micro April is Autism Month .
Reply:Well been doing a little practicing here's some 7018 flat.And here is some vertical up that my friend told me I should try to master. OK fellas what am I doing wrong 7018 rod 1/8" welder settings rough 100-140 fine adjustment 50%.Will   Supports Autism Awareness                            My ToysBobCat 225 PLusMillermatic 130Miller Spectrum 300 CutmateEverlast Power Tig 185 Micro April is Autism Month .
GMT+8, 2025-12-26 16:10 , Processed in 0.092498 second(s), 18 queries .
