Transmission case. Cast aluminum 4043 or 5356
发表于 2021-8-31 23:31:37 | 显示全部楼层 |阅读模式
My friend has a transmission case with a small hair line crack. I know I can weld it, but question is should I use 4043 or 5356?Going to use a little map gas for preheat and clean the piss out of it first. Anything else recommended for 2 small crack repairs? Wrap it in a blanket?Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:The way I look at castings, is if it is cracked on the machined flange, use 5356 for strength. If it is cracked on the body and is thin and crusty and wants to spider crack, I use softer 4043. If it is a threaded hole, I open the hole and fill it with 5356 so it will hold the threads. 4043 is just too soft for threads.All other areas I use 4943.Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
Reply:Originally Posted by shovelonAll other areas I use 4943.
Reply:And no panties.
Reply:Originally Posted by zankAnd no panties.
Reply:Just a athletic supporter....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Originally Posted by zapsterYou want that fixed?Myself ....5356....V it out..No pre heat..No post heat..Just do it.Then do it again..Then do it again..You'll see.No blankets..No coats..No sleeping bags..No nightgowns.....zap!
Reply:Originally Posted by shovelonNope, 4943 is correct. Just did an engine mount with it. But seeing you only wearing your jock strap would need some therapy.
GMT+8, 2025-12-26 14:00 , Processed in 0.069610 second(s), 18 queries .
