Leaving TIG filler stuck
发表于 2021-8-31 23:31:35 | 显示全部楼层 |阅读模式
In Jody's videos, he sometimes tapers off the heat on the side of the bevel and leaves the rod stuck in the puddle. What's the point of doing this? At first, I thought it was just to keep the rod handy for restart, but then I saw him do it and break off the rod after everything cooled. Thanks.Everlast PA160-STH... and that's about it!
Reply:Keeps the end of the rod shielded and keeps the steel from key holing as much when you start moving the arc up the bevel.Last edited by SquirmyPug; 06-20-2013 at 08:58 AM.Airco Ac/Dc 300 HeliwelderMillerMatic 200 (stolen)Miller Maxstar 150STLMiller AEAD200LE (welding and generating power) Hobart MIG
Reply:Keeps the weld from cracking at the root.Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
Reply:I'd email him and ask.  One of my friends emailed a question and said he responded in a timely manner.Or you could post the question in his comments section after the video.Dave J.Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
GMT+8, 2025-12-26 14:00 , Processed in 0.114495 second(s), 18 queries .
