Welding certifications.
发表于 2021-8-31 23:31:33 | 显示全部楼层 |阅读模式
Is there any way to take the cert test without schooling? I have had training on and off the job but was laid off before i got my certification. Have experience with stick and mig. Also if there is a way about what is the cost?
Reply:I think you can just sign up through AWS and take a test.Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:Yes, find a place in your area that offers tests. Look at local tech schools, colleges, etc..  They should have someone on staff that is certified to test you..
Reply:The tests i have done before are all open v groove vertical and horizontal. If i go somewhere will they require more than that for a cert?
Reply:i don't know if there are any testing facilities in huntington or charleston, but i seem to think that there was an AWS testing facility in greenbrier county.  i cant think of any others right now that were any closer to you.  if i remeber right, the AWS website has a state by state listing of testing facilities.  if i was in huntington i would check for places in ohio and eastern kentucky, too.  maybe closer to you.
Reply:Originally Posted by opencirclesThe tests i have done before are all open v groove vertical and horizontal. If i go somewhere will they require more than that for a cert?
Reply:I have only done vertical and horizontal. There is a votech here that does welding what kind of certification would that be?
Reply:Originally Posted by opencirclesI have only done vertical and horizontal. There is a votech here that does welding what kind of certification would that be?
GMT+8, 2025-12-26 14:23 , Processed in 0.097435 second(s), 18 queries .
